Old 06-13-2013, 8:38 PM
Default New bc75xlt, won't scan
I get an all lock out message when I hit scan? how do I remove it so I can scan?
Old 06-14-2013, 1:47 PM
wtp wtp is online now
Default could be
i hate to ask this,but, did you put in any freqs?
Old 06-14-2013, 9:13 PM
GemmaKnight's Avatar
Cool
Yep. Just program some frequencies in and it should be ok.
Scanner fan for over 35 years and a proud owner of a BCD325P2, BC75XLT and BC125AT.
Old 06-15-2013, 6:45 AM
dmg1969's Avatar
It sounds like all the channel banks you have programmed are turned off. Do you know which banks you have programmed? You have 10 banks each with 30 channels. So, if you programmed frequencies into the first 3 banks...1, 2 and 3...those banks need to be turned on. Try this. Press scan and see if the bank numbers you have programmed are showing at the top of the display. If they are not, press the corresponding number on the keypad while scanning and they will activated. See the bottom of page 39 of the manual found here. http://www.uniden.com/content/ebiz/u.../BC75XLTom.pdf
It is also possible that you somehow locked out all of the channels you have programmed. You can unlocked them all by doing this...while the scanner is scanning, press Hold. Now press and hold in the L/O button until the scanner beeps twice and displays CLEAR. Hit the E button to unlock all.
I do see in the manual that All Lock Out does display when you initially turn the scanner on. Are you SURE that you programmed the scanner correctly? To see if you did, do this. While the scanner is scanning, press Hold to stop it. Now press the 1 button on the keypad and then Hold again to take you to channel 1. This should have been the first channel you programmed. Is there a frequency? Now, step through your channels using the scroll knob on the top to double check each channel that you programmed for the frequency and that it is unlocked.
HTH.
Dave
My Scanners: HP-1, BC125AT, BC355N and Baofeng UV-5R2
Founder Perry County Pennsylvania Scanner Enthusiasts Group on Facebook
https://www.facebook.com/groups/407409399385884/
