Old 07-21-2013, 10:16 AM
robertpearsall's Avatar
Default BCT15X Tap
If I tap my bct15x will it decode p25 cc data to run unitrunker or just Analog.
Motorola APX7000, Motorola CDM1250 ,Motorola Spectra, PSR500 x3, PRO404 ,PRO668 ,BCD436HP & Too many other Vintage Radios to list
GMRS WQLT798
Old 07-21-2013, 1:47 PM
Tweekerbob's Avatar
Yes, you can decode the p25 trunking signals.
I'm OCD with ADD. Everything's gotta be perfect...just for a little bit.
Old 07-21-2013, 2:39 PM
I have just completed one for my BCT15x and it was surprisingly quick and easy. One question though, is it normal for the decoded transmissions to sound `echoey'?
Old 07-21-2013, 2:49 PM
Mine was also easy but unable to decode p25 works great on type II is there a trick I'm trying to decode the njpsic system
GMRS WQLT798
Old 07-21-2013, 3:29 PM
I have noticed mine decodes Motorola type 2 p25 pretty good albeit with that echo, but other systems round here come on as -p25 and dont translate too well. I understand it has to do with signal strength.
Old 07-21-2013, 4:51 PM
I have full bars and two systems I try don't work
GMRS WQLT798
Old 07-21-2013, 4:58 PM
I just took a quick look for you at that system and it says some talk groups are P25 phase 2 which as yet hasnt been decoded by DSD.
Old 07-21-2013, 8:20 PM
Tweekerbob's Avatar
That seems strange. Unitrunker is obvioulsy not getting the signal, or it's been told not to process it. Double check the obvious:
Make sure the AF signal is getting to it. Check the Scope tab on the receiver you have set-up as Signal. Make sure there IS a signal.
In the Info tab of that same receiver, make sure the APCO 25 box has a big X in it.
Old 07-21-2013, 8:21 PM
Tweekerbob's Avatar
He is talking about decoding the Control Channel Data from a p25 system, not actually decoding the voice.
