  #201 (permalink)
Old 10-29-2013, 7:58 PM
garys's Avatar
Originally Posted by N8OAY View Post
Finding the micro USB cables is not a problem. Staples, Best Buy, Walmart all have them.
The cable used on the Uniden DMA scanners is not a regular micro USB cable. It's not proprietary to Uniden, but as I recall, it was mostly used on cameras.
  #202 (permalink)
Old 11-03-2013, 1:42 AM
ANAVAGH's Avatar
Default Re: New Uniden BCD536HP AMWUB375
Same cable on the home patrol works on my garmin GPS.
/v\™ P25!
  #203 (permalink)
Old 11-04-2013, 7:22 PM
qc's Avatar
qc qc is offline
Default BCD536HP Canada Certification Approval
The BCD536HP just Received Certification Approval on 10-4-13 for Canada the Certification Number: 513C-UB375 here is a link Model : BCD536HP - Radio Equipment List (REL) - Certification and Engineering Bureau - Industry Canada unfortunately the Certification and Engineering Bureau does not publish or provide copies of the user manual or setup photos
  #204 (permalink)
Old 11-04-2013, 8:02 PM
Jay911's Avatar
Interesting that the frequency range includes 1.2 to 1.3 GHz. IIRC, the HP doesn't extend to this range, though others have in the past.
--j.
@Jay91150 and @RMESFire | http://www.rmesfire.org
  #205 (permalink)
Old 11-05-2013, 3:27 AM
Boatanchor's Avatar
Nice to see continuous coverage between 25 and 512Mhz retained too (if the info in the link is accurate).
Now, if there is a detachable remote head too.....
What can go wrong, will inevitably go wrong!
  #206 (permalink)
Old 11-05-2013, 3:58 AM
bear780ks's Avatar
Yea that is a nice coverage spread, I wonder when in the near future we'll see a full return of the 800mhz spectrum) with Cellphones were there at now it would be nice to see the full band return or at least the partial part of it..
Side Note Question to ask: Mr. Jay hey what the weather like up in your area is it really getting cold any snow flying or on the Ground.. Thanks Ra..
  #207 (permalink)
Old 11-05-2013, 6:39 AM
Jay911's Avatar
It's 0530 as I write this getting up on my way into work. We're in the middle of a cold snap; temp is -16C (+3F). We have had ~6-10 inches of snow each of the past two weekends. The first batch melted swiftly but the rest looks like it will stay a while. Luckily the new truck has heated seats.
--j.
  #208 (permalink)
Old 11-05-2013, 7:53 AM
bear780ks's Avatar
Hey Jay thanks.. have safe day at work.. And the rain is moving in close to our Area,
  #209 (permalink)
Old 11-05-2013, 8:46 PM
N8OAY's Avatar
One of my all-time favorite scanners, which I still use regularly, is the Radio Shack PRO-26 which was manufactured by Uniden. It has continuous coverage from 25 MHz to 1.3 GHz. I bought it instead of the BC-3000 because it used individual batteries instead of a sealed pack that was in Uniden's own products at that time. I think it has the same specs except for the number of memory channels. It was in my not humble opinion the best portable of the mid 1990s.
Dave Marshall N8OAY
PSR-500, PRO-96, BC780XLT, PRO-2067, PRO-2006/OptoScan 456, FT-7900, VX5R, VX150
  #210 (permalink)
Old 11-05-2013, 9:04 PM
Quite a bit of difference between the Pro-26 you refer to and this Pro-26:
Realistic Pocket Scanner Pro 26 FM Monitor Receiver with 4 Crystals | eBay
Wonder how much confusion using the same model numbers for different radios caused?
  #211 (permalink)
Old 11-05-2013, 9:11 PM
N8OAY's Avatar
I'm betting that guy mis-typed the model number. This is the PRO-26
Pro-26 - The RadioReference Wiki
And this is the BC-3000XLT of which the PRO-26 is a clone.
BC3000XLT - The RadioReference Wiki
Dave Marshall N8OAY
  #212 (permalink)
Old 11-05-2013, 9:18 PM
Radio Shack has reused a lot of model numbers over the years.
I once bought a service manual for the Pro-26 and it was really for the Pro-26 but not for the current model, it was for the much older crystal model!
I've even seen them reuse their internal model numbers.
You can find it if you search that site that has all the old RadioShack catalogs online. I can't recall that sites URL but it will show they used the same model numbers.
  #213 (permalink)
Old 11-05-2013, 9:31 PM
N8OAY's Avatar
OOPS! You are right! And I had a crystal PRO-26, and forgot about it. It was the last crystal scanner that they sold.
Uniden used BC-100XLT twice, I think. The first one was an update of the 16 channel first programmable portable with tubes for the batteries to prevent the batteries from breaking contact when the scanner was shaken or bumped, which caused it to lose it's memory and having to be reprogrammed. The second BC-100XLT was a 100 channel portable made maybe 5 or 6 years later with a slide-on sealed battery pack.
Dave Marshall N8OAY
  #214 (permalink)
Old 11-06-2013, 6:12 AM
MikeOxlong's Avatar
Forums Manager/Global DB Admin/Commie
Guys, let's keep in mind that this thread is for discussion of the new Uniden BCD536HP not for reminiscing about scanners you used to own.
Please stay on topic.
Thanks.
Mike.
  #215 (permalink)
Old 11-16-2013, 3:16 PM
Lot of good info on the 536 on this site.
BCD536HP - $599.95 : The Hamstation!, Your one stop on-line source for amateur radio fun.
  #216 (permalink)
Old 11-16-2013, 3:38 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Let's take the conversation to the sticky thread for the BCD536HP.
http://forums.radioreference.com/uni...on-thread.html
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
