Go Back   The Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Thread Archives
Old 10-15-2013, 11:04 PM
Default Home Patrol Reception & Charger Weird Prob
I'd be so grateful is anyone can solve this for me. When I use my Home Patrol on batteries and the stock antenna or a larger outdoor antenna I have, it works great. Reception is perfect. However, whenever I connect the a/c adapter I can literally see my signal strength drop by 3/4 or more sometimes. Unplug the adapter from either the wall side or at the HP and it returns to normal strength. I've tested this over and over, changed outlets, turned the plug around both at the outlet and the HP. Basically, I've done everything to test, shake and wiggle to find out why it does this. Nothing is loose, connections are fine. It's like the adapter is shorting out the reception of the antenna.
The only thing that I can think of that might be causing this is the AC adapter is an aftermarket charger I bought that I was told will work for the HP. Same voltage output 9W positive tip. Would this be causing it and I would need to get an OEM charger?
Old 10-16-2013, 8:59 AM
UPMan's Avatar
Uniden Representative
It is possible (likely) that the aftermarket adapter generates a lot of RF noise. This noise could cause the receiver's AGC circuit to activate (it automatically reduces the overall sensitivity in the presence of strong RF to protect the receiver circuitry).
(Sound familiar? )
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
All information here is Copyright 2012 by LLC and Lindsay C. Blanton III.Ad Management by RedTyger
Copyright 2015 by LLC Privacy Policy  |  Terms and Conditions
