Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Thread Archives
Uniden Thread Archives A depository of archived threads from the original Uniden forum.
Old 11-02-2013, 6:12 PM
Default BC-RH96 Help!!!
is anyone else having a problem with the rh96 showing unconnected with BCD996XT?
Old 11-02-2013, 7:18 PM
MikeOxlong's Avatar
Global DB Admin/Senior Mod
Have you checked to make sure you've got the latest firmware?
Mike.
To contact me please use the email function through my profile as I do not accept Private Messages.
Old 11-02-2013, 7:26 PM
updated today before hooking up,still get the same error"scanner unconnected"
Old 11-02-2013, 8:09 PM
ChrisP's Avatar
I believe the RH-96 was only designed to work with the 396T & 996T series of scanners. It requires a firmware update to function with the XT series of radios;
BCRH96FirmwareUpdate < UnidenMan4 < TWiki
- Chris
Chris Parris
The Spectrum Monitor Magazine, www.thespectrummonitor.com
chrisparris@thefedfilescom
http://mt-fedfiles.blogspot.com/
Old 11-02-2013, 8:24 PM
Chris P says, check the firmware version. If it says Version 2.00.01 that is compatible with the XT scanners. Depending on what the RH96 was made, it might have the older version.
The other possibility, although remote (no pun intended), is that the cable is bad. I had that happen, but not right out of the box.
Old 11-02-2013, 10:12 PM
ok i think i found the problem.(?)i decided to open the unit up and what did i find?....the remote port soldered to the board has scorch marks at the point where the solder attatches the two.!HA Brand new my ***!he sold me a unit that was used(the last one in this region besides ebay) claiming it was new!
Old 11-02-2013, 10:15 PM
my ? is now,would it be cheaper to have a shop(other than sellers)try to "fix" this seemingly easy task,or return the "last one available"to the seller?
