Old 11-10-2013, 5:50 PM
Default Scanning Bcd796D
Looking for a little input or help, I have updated the firmware and programmed new frequencies and talk groups to scanner via Proscan. When selecting scan can NOT hear nothing, when selecting Hold/Man and select a frequency alone it will pick up some talkgroups. Why is it not picking up talkgroups during scan?
Old 11-10-2013, 6:17 PM
mule1075's Avatar
Do you have the trunking type set correctly?
Uniden BCD536HP/436HP/796D/250D Motorola HT1000/GM360
Old 11-10-2013, 6:24 PM
Wiki Admin Emeritus
A much better question - what system are you trying to hear? Go up to the toolbar directly under the site title, float your mouse over Database then select Frequency Database Use the maps and pulldowns to get to the URL of your system, then c'mon back with that. Then more folks can help you.
