Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Thread Archives
Uniden Thread Archives A depository of archived threads from the original Uniden forum.
  #541 (permalink)
Old 11-27-2013, 3:37 PM
Jay911's Avatar
Originally Posted by Gilligan View Post
Would the BCD436HP show the tones on a search if the search is analog only? For example, if I were to search the UHF business band in analog-only mode, would it show the tones in use?
That's how the HomePatrol works, and this is based on the HomePatrol, so one would presume that you are correct.
  #542 (permalink)
Old 11-27-2013, 3:38 PM
Originally Posted by PanJurekMrJerry View Post
Will the BCD436HP decode regular TDMA in addition to X2-TDMA and what is the difference between the two? Also how come there is no Mototrbo or NXDN?
If by "regular TDMA" you mean P25 Phase II then the answer is yes.
If you're talking about any of the several other types of TDMA, no.
Oh, and the difference between X2 and P25 Phase II? Different digital formats. (like WAV vs MP3)
Joe M.
  #543 (permalink)
Old 11-27-2013, 4:15 PM
Which USB does the BCD436HP use:
2.0 Mini Type B OR 2.0 Micro Type B?
Manual does not say and by looking at UPMan's Video on the 436 I was able to rule-out the other two possibilities.
  #544 (permalink)
Old 11-27-2013, 4:20 PM
It looked to me like it was a mini but after viewing it again I'm not too sure.
  #545 (permalink)
Old 11-27-2013, 4:29 PM
Jay911's Avatar
Default Re: BCD436HP Discussion Thread
Mini B.
  #546 (permalink)
Old 11-27-2013, 7:12 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
For those wanting to see the side connectors these 2 pics have shown
up from somewhere....
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
http://instagram.com/KE4ZNR
  #547 (permalink)
Old 11-27-2013, 10:30 PM
rlkeithp's Avatar
Hey Guy's I cann't seem to tell but can this scanner be hooked up to an external antenna and if so would it plug in were the stock one is or somewhere else?? If going to use as a base station also.... Thanks
  #548 (permalink)
Old 11-28-2013, 7:41 AM
Yes it can. It goes where the stock one goes. Just make sure your external antenna connection is SMA or BNC as the scanner comes with an sma-bnc adapter.
Sent from my Galaxy Nexus using Tapatalk
  #549 (permalink)
Old 11-28-2013, 8:03 AM
bear780ks's Avatar
Default Micro VS Mini..
I thought Uniden might use the Micro USB instead of the mini as reliability is suppose to be some what better.. And Space Saving..
  #550 (permalink)
Old 11-28-2013, 9:19 AM
Jay911's Avatar
Takes up pretty much the same amount of space. It's also somewhat easier to source a mini cable in my experience - there are probably 5 to 10 times as many mini cables/adaptors/etc as there are for micro.
  #551 (permalink)
Old 11-28-2013, 9:34 AM
KE4ZNR's Avatar
Yep.
Marshall KE4ZNR
@KE4ZNR on Twitter
  #552 (permalink)
Old 11-28-2013, 10:19 AM
bear780ks's Avatar
yea uniden has used that old style plug for a many years that's on the 396 but I don't think there is nothing wrong in switching to the mini usb I use it on allot my stuff like powered speakers and things like that. so it might of been a good move going in this direction.
Hey Jay you having Turkey Day up in your area today if so Have a Safe and Happy one Same goes to all visiting the thread here.. ya'll be Careful out there
  #553 (permalink)
Old 11-28-2013, 10:49 AM
2wayfreq's Avatar
Default Recommended L-ion Batteries and Charger
I was curious on what would be a good brand recommendation for AA L-ion batteries, MAh High-Capacity and Charger/Conditioner unit? I want to have (AT LEAST) 8-Hours of operation. I'm talking Professional Camera Grade etc. I hate batteries that die in only a few hours.
Troubleshooting Golden Rule #1: Check your connections.
  #554 (permalink)
Old 11-28-2013, 2:47 PM
Arrow
First power on of the BCD436HP. From batteries in to scanning local stuff in less than 2 minutes.
http://www.youtube.com/watch?v=iwxUJWmDbj8
  #555 (permalink)
Old 11-28-2013, 4:47 PM
markbart's Avatar
That looks good.
PopCom Station ID. WPC1MBB
Proud Owen County IN Weather Spotter
Pro-2055 Pro-197
KAKC 0870
  #556 (permalink)
Old 11-28-2013, 4:59 PM
Boatanchor's Avatar
Default Poor LCD display?
Just watched the latest UPMAN video of the 436HP and I have to say that I agree with one of the comments.
The display format on the 436HP seems to be a real backwards step from the HP1 and maybe even the 396XT.
What can go wrong, will go wrong!
FuncubeDongle Pro+ - PSR600 - PSR500 - BCD996XT - BCD396XT - TM9155 - IC-208H, amongst others :-)
  #557 (permalink)
Old 11-28-2013, 8:00 PM
stingray327's Avatar
Question
Where is the link to this?
  #558 (permalink)
Old 11-28-2013, 8:08 PM
Jay911's Avatar
Seriously?
Three posts above yours.
  #559 (permalink)
Old 11-28-2013, 8:25 PM
Boatanchor's Avatar
It probably doesn't help that it seems that the LCD illumination is switched off by default at first power up and towards the end of the video, the lights go out
Regardless, the GUI and LCD display hardware does appear to be a bit primitive compared to almost every other electronic consumer device being sold today..
Maybe it's a case of all function and little form. Lets hope so!
  #560 (permalink)
Old 11-28-2013, 8:40 PM
kayi4cle's Avatar
Default Font size?
Originally Posted by markbart View Post
That looks good.
I agree; it does look good. The display is taller, but I can't tell from the video if it is wider (to allow for larger letters/numbers). I have a hard time reading my 346XT display. Does anyone know if the font size is larger than the BC346XT? Thanks!
Tags
bcd436hp, bcd536hp
