Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Thread Archives
Uniden Thread Archives A depository of archived threads from the original Uniden forum.
Old 12-08-2013, 7:48 AM
nosoup4u's Avatar
Default Convert Freescan GPS entries to home patrol
I am trying to convert my GPS settings from my 996xt over to my HP1, however when I did a test run, many groups that should have been locked out were not (and vice versa). I have a couple of questions.
Should the HP be set for DMS or DEG?
When copying from FreeSCAN, do I take the entries from the group screen, or should I hit edit and cut and paste from that screen?
What is confusing me is on the group screen, I see Latitude as 40.495635N, but if I go to the edit screen it shows 40.832319. I had cut and pasted from the edit screen for the bulk of my GPS Entries.
John - KC2KZZ
http://www.warrenskywarn.org
BCD536HP, BCD436HP, BCD996XT (w/GPS) Home Patrol-1, BCT15 & BC346XT
@kc2kzz - My Twitter feed. @WCAlerts - Warren County Fire/EMS alerts
Old 12-13-2013, 6:32 PM
Hope this helps. I can explain the difference between DMS and DEG if interested.
Note: Although the coordinates are entered in Degree format, there is an internal conversion to DMS, which is the format the GPS-enabled scanners use. So although the two sets of figures might not match when you look on the edit screen, they still point to the correct location.
FreeSCAN-GPS - The RadioReference Wiki
BCD396XT, BC245XLT & Pro-164
Fleet of TK-8180, 880, 3173, & 3160
