  #121 (permalink)
Old 01-25-2014, 4:44 PM
gonzalu's Avatar
Originally Posted by Seymourmtn View Post
I downloaded wine and Sentinel with no problems, to my Mac Air
However, am having problems connecting to my 536.
Sentinel doesn't recognize my MicroSd card.
Anyone else?
Doug
Using VMware Fusion on Mac Air (Mavericks 10.9.1 and Windows 8.1 Enterprise x64) with no issues. Only thing I had to do special was run the Wi-Fi Dongle Firmware Updater as Admin... that's it.
When you plug in your scanner via USB to the Mac, in VMWare, it will ask if to present it to MacOS or to WinOS. IF your WINE has a similar option, make sure the USB port is being sent to Windows, not the host OS.
Manny, N2MAV - Amateur Extra
BCD536HP, BCD996XT, HomePatrol-1, BC125AT, PCR1000, PRO-2042, OS-535, FT-857D, IC-U16
First Scanner: Realistic PRO-24
  #122 (permalink)
Old 01-25-2014, 4:56 PM
jh2000's Avatar
I'm in USA and planning to but the Uniden BCD536HP.
I see some or all dealers may be out of stock.
Can anyone recommend a reputable dealer and comment on availability of this model?
Thanks in advance.
  #123 (permalink)
Old 01-25-2014, 4:59 PM
Wine doesn't have native USB support, so it's a no go on easy street. The wireless dongle shows up as an ACM0 device on Linux, so its likely possible to symbolically link it to a comm port in wine, haven't tried it yet. (wanted to make sure my new hardware was in good working order before hacking on it)
I will however to serious debugging when the next firmware lands.
This message is hidden because Voyager is on your ignore list.
  #124 (permalink)
Old 01-25-2014, 5:05 PM
NHdave's Avatar
Thanks in advance.
Being discussed here http://forums.radioreference.com/uni...t-sources.html
________________________________
BCD996XT, Pro 106, Pro 2053, BC350A, BC120xlt
  #125 (permalink)
Old 01-25-2014, 5:13 PM
03msc's Avatar
Originally Posted by teknishun View Post
I am quite surprised at how the 536HP performs indoors with just the stock telescoping antenna.
It is even doing a fair job with the P25. None of my other scanners perform this well!
I am scanning the full database for my state/county and I am hearing stuff I never knew was possible with the indoor antenna. I also found Houston Fire Dispatch (HFD bot) being transmitted in a new place that I did not know was there. I am still looking for that inside the RR databases.
So far I like the 536HP much better than the 996XT.
One strange thing though. The 996XT came with the external DIN sleeve included.
The 536HP says it is optional (have to pay more money to get it).
I wonder why it wasn't included?
Probably because so few use it. Cuts a little cost for Uniden on production side to leave it out. Honestly this setup makes more sense to me. Let it be an optional piece for those who do want it.
Mark Arkansas
Uniden Whistler Kenwood Yaesu
  #126 (permalink)
Old 01-25-2014, 6:40 PM
kbod9633's Avatar
Imagine my sadness this morning I'm a otr truck driver run coast to coast and was 10 miles from scanner master thought hey I'll run over and grab a new 536 about 5 miles out I called and they are closed on the weekends lol just my luck
Sent from my DROID RAZR HD using Tapatalk
Bob
3 BCD536HP's , 2 BCD436HP's , BCD996XT, 2 TRX-1's , PRO-96
  #127 (permalink)
Old 01-25-2014, 6:42 PM
troymail's Avatar
Originally Posted by UPMan View Post
I corrected it (had changed some things mid-stream to make it easier and missed changing the file name/structure).
I think these instructions still need work -- took me quite a while to get the install to work. First tried as normal user then logged in as administrator - eventually, remembered someone posted something about running as XP Service Pack 3 mode. Far from straight forward.
Windows 7 Home Premium 64-bit
Unication G5(UHF)
  #128 (permalink)
Old 01-25-2014, 6:58 PM
4482's Avatar
Thanks in advance.
My new BCD536HP scanner will be here Tuesday from HRO. I ordered it yesterday. (Friday)
  #129 (permalink)
Old 01-25-2014, 7:22 PM
troymail's Avatar
UPMan - I'm seeing something "odd" -- I used Sentinel to create a favorites for Baltimore City (all talkgroups) but I trimmed the frequency list down to just the control channel frequency. When I enable that favorite on the 536, it shows "Scan Mode, Nothing to Scan".
So I created a 2nd favorites list - same thing except that I left all frequencies programmed. That seems to work fine.
Note- I've created several single site/frequency favorites and others are working as expected.
So.... through the keypad on the radio, I modified the single site/frequency version of the system and added a 2nd frequency.... now it works....
So.... through the keypad again, I modified the single site/frequency version of the system and removed the extra frequency I just added -- and it still works...
Unication G5(UHF)
  #130 (permalink)
Old 01-25-2014, 7:27 PM
Did you check to see if the single frequency was actually a CC in use or just one that was designated as the control channel. Perhaps the second frequency you enter is a good CC?
Just guessing here.
  #131 (permalink)
Old 01-25-2014, 7:29 PM
troymail's Avatar
Just guessing here.
Good thought but no - the single frequency IS the active CC.
Unication G5(UHF)
  #132 (permalink)
Old 01-25-2014, 8:12 PM
ok what am i doing wrong?? i have all of my favorite lists built and i have assigned each list a fl quick key but say i want list 1 and hit the 1 key the quick key navigation screen comes up and thats as far as i get ??
  #133 (permalink)
Old 01-25-2014, 8:16 PM
troymail's Avatar
Did you follow that with E/yes?
It also seems that if a given favorites list isn't enabled from the "Set Scan Selection" menu, you cannot toggle that favorites list on/off from the numeric keypad (if the FL # isn't showing up on the "F0" line, you can't toggle it on/off)
Unication G5(UHF)
  #134 (permalink)
Old 01-25-2014, 8:45 PM
thank you i didnt have the set scan selection
  #135 (permalink)
Old 01-25-2014, 9:27 PM
Smile BCD536HP availability
Thanks in advance.
The BCD536HP is a brand new model being released this month.
Many dealers are still waiting on their first shipments from the factory.
Hundreds of "pre-orders" were taken back in December.
The dealers are trying to fill the pre-orders as quickly as possible.
If dealers are out of stock it just means they are awaiting the next
shipment. It is a temporary thing. I just received mine yesterday.
You might get one quicker by ordering it online. I would suggest, and
this is purely my own opinion, that you check at scannermaster.com
or bearcatwarehouse.com I have ordered from both with good results.
Right now both the BCD436HP (portable handheld) and the BCD536HP
are in hot demand. Just be patient. This scanner is well worth waiting
for !!!
  #136 (permalink)
Old 01-25-2014, 9:40 PM
Unhappy Instructions need work ??
I have the same Windows OS as you. I got the files downloaded and unzipped and
ran the installs just fine. The very last step, the place you point the program to
the dongle COM port and to the program location is where mine aborts.
I think I'll wait a little longer until the instructions can be made more clear.
Besides, we cannot use the dongle yet anyway because the app for it has
not been released yet.
  #137 (permalink)
Old 01-25-2014, 9:56 PM
Smile BCD536HP Screens
Originally Posted by ButchGone View Post
Based on the videos I've seen so far, the screens are blue, not white. But then again, the "white" screen setting on the 396xt is actually blue as well. And no, it's not a camera white balance issue either, as some have suggested because the function keys on the 536 are brilliant white. Not a big deal tho, because it appears the new models are outstanding on simulcast decode! I will be ordering one too!
BG..
Mine is definitely not white. It has a bluish hue. But it is easy on the eyes and is crisp
and clear. I guess it depends on how you set the brightness and contrast.
I run mine with the 3 line display off. You get more info but in smaller fonts. See owner's manual
page 27 and 28. Even then it is still easy to read.
  #138 (permalink)
Old 01-25-2014, 10:25 PM
Smile Re: Alpha Tags vs Description
I have discovered the BCD536HP does not use the RR alpha tags on the display. Instead it uses the Description field. You cannot distinguish whether you are listening to "Texas Wide Area Radio Network" or to "Texas Wide Area Radio Network P25." Both get chopped down to "Texas Wide Area Radio Netw..."
Perhaps RR database could put the P25 closer to the front of the line, like maybe as the first 3 characters of the name?
I think I have answered my own question. I have been watching this scanner all afternoon
and having a ball discovering all the things it will pick up with just the stock antenna.
The TxWARN P25 (digital) will show a "P25" or "DAT" or "LNK" at the top right of the display.
The TxWARN (analog ) will just show "NFM" for narrowband FM at the bottom of the screen
without the indicators above.
  #139 (permalink)
Old 01-25-2014, 10:40 PM
1Partsman's Avatar
teknishun....
unless I am misunderstanding what you want to do, it is real easy using the Sentinal software to change the description....just edit it in the favorite list....unless of course you have to do it to lots of systems.....
John
536HP 396xt PRO433 PRO99 208A T90A 890XLT
as I get older, it takes me time to learn new technology, please be patient, cause I want to learn more...so I too can pass it on to others
  #140 (permalink)
Old 01-25-2014, 10:41 PM
Default Scanners in Stock!
Hi Group; I was the first to pick one up at AES Amateur Electronic Supply in Wickliffe, Ohio. They received a case and had only sold 2.
