Did I miss something? Here are the instructions for the WiFi dongle:
1. Download Wi-Fi-Updater.zip.
2. Unzip the files downloaded in Step 1. Then, unzip the files in STM_VCP.zip.
3. Navigate to the STM_VCP directory and run either VCP_V1.3.1_Setup.exe or VCP_V1.3.1_Setup_x64.exe depending on whether you are running a 32-bit or 64-bit OS.
4. Plug the Wi-Fi dongle directly into a USB port on your PC and allow it to install.
5. Unzip the files in FWUpdate_WriteData_UartDisable_ver.5.1.zip.
6. Navigate to the FWUpdate_WriteData_UartDisable_ver.5.1 directory, then run Setup.exe to install the updater.
7. Run the program you installed in Step 6 by navigating to the Uniden --> BCDx36HP --> BC_Wifi_Updater application launcher in your programs list.
8. When prompted, point the updater to the FWUpdate_WriteData_UartDisable_ver.5.1.bin file part of what you unzipped in Step 2.
When I unzipped "Wi-Fi-Updater.zip", it contained "STM_VCP.zip" as described in the instructions. But I can't do step 5, because the only other two files in the main zip file are:
FWUpdate_WriteData_UartDisable_ver.5.1.bin [NOT .zip]
and
BC-WF1_FirmwareUpdater_Version0.00.03.zip [not mentioned in the instructions]
The "BC-WF1... zip" file does have a "setup.exe" in it. Are we supposed to unzip that file, then in step 8, point the program at the .bin file that was in the main "Wi-Fi-Updater.zip" file? I.e., should steps 5 & 6 refer to "BC-WF1_FirmwareUpdater_Version0.00.03.zip" instead?
Thanks.
...R
