Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Thread Archives
Uniden Thread Archives A depository of archived threads from the original Uniden forum.
Old 01-18-2014, 12:44 PM
UPMan's Avatar
Uniden Representative
Default BCD536HP Post-Release Thread
Read/perform the following as soon as you get your new scanner.
BCD536HP < UnidenMan4 < TWiki
Previous discussion is at http://forums.radioreference.com/uni...on-thread.html.
Discuss actual performance results, below.
Uniden Product Ninja
Professional Scanner Developer
Old 01-18-2014, 8:47 PM
Administrator
ATTENTION ALL:
To help the participants in this thread please restrict your post to your experiences with the scanner. This is not the place to complain; you're more than welcome to but please voice that in your own thread. If you need help with how to use the scanner this is not the thread for you. You will get the best help by starting your own thread.
We will at our discretion delete your post without warning if you do not heed our requests. We thank you for your cooperation and I'm sure the lurkers will too. I hate to have to make these types of posts but the past threads have shown they're needed.
To contact me please use the forum email function as I do not accept Private Messages unless you're on my contact list.
All rules and guidelines are covered in this forum. These are required reading for new members and all existing should follow for any updates.
Old 01-18-2014, 9:49 PM
wise871's Avatar
FL, GA, AL, MS Admin
I'll be the first to report an experience I discovered. You now have the ability to turn individual national database systems on and off. With the HP-1 you could only turn on/off the entire systems and avoid what you didn't want to monitor. Now in the 536 you can Select Nationwide Systems and turn them on and off individually. Example in the menu you now have Air Show - USA, Amateur Radio - USA, American Red Cross-USA, etc. This option is not in the Sentinel Software that I have found.
Dan M
BCD436HP /BCD536HP /BCD396XT /BCD996T(XT) /BCT15X /PRO-197 /PRO-106 /PSR-410 /HP-1 /BC898T
Old 01-19-2014, 10:25 AM
rgore's Avatar
You sure the HP-1 doesn't have this feature? If I go from the "Main Menu" in my HP to "Advanced Menu" then "Select Nationwide Systems" I get the same options to turn "Air Show - USA" on or off..
OUT.
Old 01-19-2014, 10:37 AM
wise871's Avatar
OUT.
I stand corrected. I never saw that on my HP-1. Thanks for point that out.
Dan M
Old 01-20-2014, 3:56 AM
wm8s's Avatar
Did I miss something? Here are the instructions for the WiFi dongle:
1. Download Wi-Fi-Updater.zip.
2. Unzip the files downloaded in Step 1. Then, unzip the files in STM_VCP.zip.
3. Navigate to the STM_VCP directory and run either VCP_V1.3.1_Setup.exe or VCP_V1.3.1_Setup_x64.exe depending on whether you are running a 32-bit or 64-bit OS.
4. Plug the Wi-Fi dongle directly into a USB port on your PC and allow it to install.
5. Unzip the files in FWUpdate_WriteData_UartDisable_ver.5.1.zip.
6. Navigate to the FWUpdate_WriteData_UartDisable_ver.5.1 directory, then run Setup.exe to install the updater.
7. Run the program you installed in Step 6 by navigating to the Uniden --> BCDx36HP --> BC_Wifi_Updater application launcher in your programs list.
8. When prompted, point the updater to the FWUpdate_WriteData_UartDisable_ver.5.1.bin file part of what you unzipped in Step 2.
When I unzipped "Wi-Fi-Updater.zip", it contained "STM_VCP.zip" as described in the instructions. But I can't do step 5, because the only other two files in the main zip file are:
FWUpdate_WriteData_UartDisable_ver.5.1.bin [NOT .zip]
and
BC-WF1_FirmwareUpdater_Version0.00.03.zip [not mentioned in the instructions]
The "BC-WF1... zip" file does have a "setup.exe" in it. Are we supposed to unzip that file, then in step 8, point the program at the .bin file that was in the main "Wi-Fi-Updater.zip" file? I.e., should steps 5 & 6 refer to "BC-WF1_FirmwareUpdater_Version0.00.03.zip" instead?
Thanks.
...R
Old 01-20-2014, 4:30 AM
wm8s's Avatar
The 536 manual contains this warning:
WARNING! If you connect an external speaker to the scannerís Ext. SP jack or headphone
jack, never connect the audio output line to a power supply and ground. This might
also damage the scanner.
BCD536HP Only - All audio output is Class-D amplified (PWM). Never connect Ext. SP
jack or headphone jack to an external Class-D AMP.
I'm not sure why anyone would ever "connect the audio output line to a power supply." Is it safe to connect the 536 to any external audio amplifier? 0.8W isn't much. I was thinking of connecting mine to an amplified speaker and be able to switch it over to the Radio input on a PA/Siren box for routing to a grill speaker.
Thanks!
Old 01-20-2014, 7:45 AM
and
Thanks.
...R
Yep, I noticed that too. The instructions do not correspond to the folder/file structure of the download.
Old 01-20-2014, 8:44 AM
and
Thanks.
...R
It should say:
5. Unzip the files in BC-WF1_FirmwareUpdater_Version0.00.03.zip
6. Navigate to BC-WF1_FirmwareUpdater_Version0.00.03.
BCD436HP, BCD536HP, Pro-106, Pro-97, PSR800, PSR310, BR330T, and wishing for a real base (not mobile) trunking scanner.
Old 01-20-2014, 8:54 AM
UPMan's Avatar
I corrected it (had changed some things mid-stream to make it easier and missed changing the file name/structure).
Old 01-22-2014, 8:37 PM
Default Amazon Has them
Amazon can get you a 536 at a slightly higher cost if someone is interested.
Jim
Old 01-22-2014, 8:46 PM
N8IAA's Avatar
Jim
More than $600? Why would you do that
Larry
Digital/Analog scanning and hamming
Old 01-22-2014, 8:50 PM
Just putting the info out there.
Old 01-22-2014, 9:01 PM
03msc's Avatar
Larry
I agree...but...notice it is free shipping...and if a retailer website charged $25 shipping on top of $599, well...same difference.
Mark | Arkansas
Radio Shack Pro-106 | Uniden HP-1, BCD996XT, BCT15X | Kenwood, Icom, Yaesu Radios
Thanks for being a part of the RR Community! ~~~ Please read existing threads before posting!
Old 01-22-2014, 9:18 PM
Not sure if this is true or not but I think you have to pay state tax on all items on Amazon now. That would be about 50 bucks extra in taxes I think. Correct me if I am wrong
Old 01-22-2014, 9:19 PM
Yeah. You are right. It should still be cheaper to get it from a smaller retailer.
Sent from my Nexus 7 using Tapatalk
Default sales tax
That is correct
Old 01-22-2014, 9:22 PM
Some may have to, but not all....
Old 01-22-2014, 9:24 PM
I just tried adding it to my cart and they did not add any sales tax. I wish I could afford to buy it
Old 01-22-2014, 9:58 PM
Default Re: BCD536HP Post-Release Thread
It all depends on the warehouse that the item ships from. If I order something that ships from an Arizona warehouse I am charged state taxes on it. If it ships from an out of state warehouse I am not charged any state sales tax.
Sent from my fertile imagination.
Uniden BCD436HP
