Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > Uniden Forums > Uniden Thread Archives
Uniden Thread Archives A depository of archived threads from the original Uniden forum.
Old 02-11-2014, 3:21 PM
Default BCD436HP Tone-out feature not working
I set up the tone-out feature with 5 different 2-tone combinations on the same frequency but nothing ever happens on the scanner when any of the tone sets go out. I don't see any on/off selection so I assume tone-out is always on when the scanner is on. Anybody have experience with this?
Old 02-11-2014, 4:29 PM
I am pretty sure you have to be in "Fire Tone Out" mode. At least you did in the older models. I have not played with it yet on the 436.
Old 02-11-2014, 5:00 PM
NHdave's Avatar
You need to be in tone-out mode, page 77 of the manual tells you how to do that.
________________________________
Pro 106, Pro 2053, BC350A, BC120xlt
Old 02-11-2014, 5:30 PM
W2SJW's Avatar
Senior Member
Correct, you must be sitting in the 'Tone Out Standby' mode, and then you can choose to hold on one of the tone sets you pre-programmed, or scan for the tones in real-time while sitting on the frequency.
You cannot scan tone-outs & favorite lists/main database at the same time.
Scott
NJ & PA Database Admin
My BCDx36 Files
Old 02-11-2014, 5:56 PM
I had a feeling that favorites and tone-out couldn't be scanned at the same time. I won't be using it since I don't want to scan just tone-outs.
Thanks for your help.
Old 02-11-2014, 9:06 PM
DaveIN's Avatar
You would need two receivers in order to monitor the channel for tones and scan at the same time.
Pop' Comm Monitoring Station ID: KPC9DV
CRB Research Monitor Station Registry: KIN9GP
GMRS: WQKL769
