Old 02-11-2014, 6:11 PM
MesquiteWx's Avatar
Default USB Mode - Selecting Serial Port BCD536HP
So I have the serial driver installed and it is installed correctly. It shows up as port 8 and connects to it in RadioFeed.
Now as some of you know who have this scanner you plug the USB in and it asks...
Mass Storage="E" Serial Port="."
Now correct me if I am wrong but isn't he . the "no" button?
When I press it to go to serial it just exits out all together and I hear it disconnect.
Am I missing something?
-Thanks
Old 02-11-2014, 6:25 PM
UPMan's Avatar
Uniden Representative
I believe what you are hearing is it connecting. The PC isn't going to see the scanner until you select which option to use, then it will attach to the scanner using whichever mode you selected.
Uniden Product Ninja
Professional Scanner Developer
Personal Blog
Old 02-11-2014, 7:31 PM
MesquiteWx's Avatar
Yep that is what it was doing. I was expecting it to connect to Sentinel through the serial connection but I guess it doesn't work that way.
Other than transferring meta data to software what other benefits does they serial connection have?
Old 02-11-2014, 8:20 PM
thecop's Avatar
Might I ask where I can find the serial driver? I just received the ARCPRO beta but cannot run the virtual screen without the driver. I plugged the USB cable in but was told the driver did not install correctly.
John
"We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm" George Orwell
Old 02-11-2014, 8:28 PM
MesquiteWx's Avatar
BCD536HP < UnidenMan4 < TWiki
Old 02-11-2014, 8:55 PM
thecop's Avatar
Thank you very much.
Old 02-12-2014, 5:46 AM
Butelsoftware's Avatar
John
Drivers come with the ARC536beta. Go to c:\program files\butel\arc536 for the drivers.
Gommert
Butel Software
>>> Visit us in november at Milipol in Paris ! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 02-12-2014, 6:08 AM
[QUOTE=Butelsoftware;2130097]Drivers come with the ARC536beta. Go to c:\program files\butel\arc536 for the drivers.
Gommert
Gommert, If we purchase the ARC536 now, do we download the beta version, or do we still have to wait?
Thank you.
Steve AA6IO
Old 02-12-2014, 8:40 AM
thecop's Avatar
Up and running. Thank you very much. Will you be creating an ARC 536HP Pro forum soon?
Gommert
Butel Software
Old 02-12-2014, 9:47 AM
[QUOTE=sshermanmd;2130101]
Gommert
Thank you.
Steve AA6IO
No wait, just send me a message after the purchase and then I will forward the latest beta.That info is also in the purchase confirmation email.
Gommert
Butel Software
Old 02-12-2014, 9:48 AM
Hopefully Uniden will add a forum to homepatrol.com soon.
Gommert
Butel Software
Old 02-12-2014, 4:53 PM
I'm running Windows 8.1 on my laptop. I installed the serial drivers. When I connect the USB cable to my scanner, Windows detects it and I can see "Uniden Serial Port (COM5)" under Ports in Device Manager. No errors. When I press "." for Serial Port on the scanner, it beeps and return to scanning.
Any suggestions? I already try to uninstall and reinstall the serial driver. I can see Uniden Serial Port in Device Manager until I unplug the USB cable from the scanner.
Lacadien72
Uniden BCD996T | Uniden BCD436HP | Uniden BCD536HP
Old 02-12-2014, 4:56 PM
This is the normal behaviour of the scanner in serial mode. Once in serial mode it can be controlled by software.
Gommert
Butel Software
Old 02-12-2014, 5:09 PM
MesquiteWx's Avatar
This was the premise of my original question.
As stated that is normal.
I was expecting something different too. It doesn't work as you would normally expect.
Old 02-12-2014, 6:27 PM
Ok thanks. I bought ARC536 Pro and running the beta version. ARC536PRO Virtual Control Beta is not working and I thought it was related to the driver.
Lacadien72
Old 02-12-2014, 6:30 PM
MesquiteWx's Avatar
Doesn't sound like a driver problem. Do you have any other programs you can test it with like RadioFeed that is free just so you can see if it is sending data? Only take a second to setup and if it works with that then you know it is a problem with the ARC536PRO software.
Old 02-12-2014, 8:53 PM
I found my problem. I did not know the number on the left of the Start button was the COM port number. I picked my COM port number and it work fine.
Lacadien72
Old 02-13-2014, 9:38 AM
[QUOTE=Butelsoftware;2130225]
Gommert
Butel Software
There wasn't any info in my confirmation email. It just said it was estimated to be released during Q1 2014.
Tags
bcd536hp, serial port
