snoker
Hello all,
Some quick background. I became interested in scanning in the early 90's (Uniden Bearcat BC200XLT that I still use now and then), and by the mid-90's I was into 2-meter/70-cm amateur radio (Yaesu FT-51, KC7KRZ).
I'm not exactly a newbie, but I'm somewhat out of touch in this decade.
In June of 2008 when the scanner bug started biting me again, I found that all of Davis County had (probably long since) gone to a Motorola trunked system, and I needed a new scanner. (Back in the mid 90's, trunked systems were somewhat novel, but I do remember conventionally scanning a Salt Lake International Airport trunked system back then...) So, back in June, I did my research, learned (from these very forums -- thank you all!) about the upcoming rebanding, and chose a Pro-164 because it was rebanding capable.
I programmed my Pro-164 using win 97 and a subscription to the Radio Reference database (thank you all, again!), and I have been enjoying it for months.
On the afternoon of December 4th, my cul-de-sac began to fill with paramedics, ambulances, and police. I grabbed my scanner and walked outside. A medical helicopter from the U of U was approaching... I turned on the Pro-164 and... radio silence.
As I learned from this forum, Davis UCAN was rebanded sometime during the evening of December 3rd. Perfect timing.
I guess that introduction was a bit long-winded, but here's what I understand, and I'm hoping someone reading can confirm this. Even though I've updated the UCAN frequencies from the recently updated database, because Motorola changed the channel spacing for its rebanded trunked systems, my Pro-164 can't scan Davis UCAN in trunked mode until I we get a firmware update from Radio Shack.
Does this mean that my only option at this point is to scan conventionally? I have read some posts about other scanners that have custom trunking table settings that could allow them to work, but I believe these were exclusively digital scanners (Pro-96, newer GRE's).
Is anyone having any luck with rebanded systems and the Pro-164? If so, any suggestions?
Maybe I'm pessimistic, but I'm afraid the firmware update will be at least several months away.
--Shawn
--Shawn
