Utah_Viper
Some have been following the thread: http://www.radioreference.com/forums/showthread.php?t=126797
Which was started for thr Pro-164, Well it somewhat turned into a Pro-162 thread. Thought I would go ahead and start a new thread for the newest issues.....
I thought I finally had things working. the biggest problem now is the scanner gets stuck everytime there is a transmission on 860.7125 then it just shows what ever was the last TG, does not scan, yet still passes the other traffic. Does it also if im trying to monitor a TG. Then I just start hearing everything as if the scanner is open mode, but the screen does not change. Anyone else having issues like this?? I am planning to try and use Nelson Peak instead of the SL Simo after I get home and see if that works.
The SLC AC33, and the Utah Communications TYS seem to be working perfect. Its just UCAN and the new band plans.
