This is the stock band plan Uniden is publishing for all their scanners that are upgraded for rebanding. But you have to go to Uniden and register to download their downloader program and the firmware update for your model. There will be all the information you need there.
For standard rebanded systems, you need to set Band Plan 1 and Band Plan 2 as:
Band Plan Base Freq (Lower) Base Freq (Upper) Offset Polarity Spacing
1 851.0250MHz 854.0000MHz 440 + 25 kHz
2 851.0125MHz 868.9875MHz 0 + 25 kHz
P.S. if you search back further there is a thread about BCD396T rebanding in here and I think the links are there.
Found it. Try reading this thread too.
http://www.radioreference.com/forums...ssistance.html
