Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Utah Radio Discussion Forum
Utah Radio Discussion Forum - Forum for discussing Radio Information in the State of Utah.
Old 06-16-2013, 5:19 PM
Default Scipio Site
Someone last summer posted the new Scipio site and two control channels, 853.43750 and 853.93750, which I have since been using successfully on every run north-south. I notice it has yet to get posted on the database. I don't have more specifics. Perhaps whoever posted that may chime in here...
Old 06-16-2013, 5:31 PM
Found it here, post #54 in this thread:
http://forums.radioreference.com/uta...stem-id-3.html
Old 06-16-2013, 6:29 PM
theaton's Avatar
Member N7VU
Thumbs up UCAN Scipio site
It looks like it belongs to WQOH738 (UTAH COMMUNICATIONS AGENCY NETWORK) FCC Callsign Details. Do you have a site number? If not I can post it with a dummy number until it is found.
-Tim
Scanning Mountaintop to Mountaintop...
Old 06-16-2013, 9:05 PM
The post in the link by bchris shows site #13 in his screen shots from October.
http://forums.radioreference.com/att...ipio-freqs.jpg
Also the link you posted is spot on, you can see the antenna array as you drive past Scipio Hill, and my signal strength meter jumps off the map when I hit the summit. Its range is roughly 50 miles.
Old 06-17-2013, 10:49 AM
theaton's Avatar
Member N7VU
Okay, I added the Scipio site. Be sure to submit any voice frequencies that you pick up. Thanks for posting this!
-Tim
Old 06-20-2013, 9:10 PM
Wirelessly posted (Mozilla/5.0 (iPod; CPU iPhone OS 6_1_3 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10B329 Safari/8536.25)
All I have is white pine's info... I moved scipio pass to my cedar city bank.. Where is scipio hill or pass exactly? I thought junior took a ride through there I don't remember if he found it though....
Old 06-20-2013, 9:16 PM
I see scipio is 643 site 13 from pics from other discussion...
Old 06-20-2013, 9:45 PM
theaton's Avatar
Member N7VU
I entered location data from the FCC license, so you should be able to see it on a map if you click on the site. You won't be hearing it from Price. :-)
-Tim
Old 06-20-2013, 9:48 PM
I know I sometimes get to travel but only got as far as Richfield and I didn't hear it to that point.
Old 07-01-2013, 10:04 PM
Lightbulb Info on Sanpete County Sites and Scipio Pass
I went to Manti Saturday I couldn't hit Scipio, I hit White Pine 643h-0017 (Site 17) I hit Barton Peak 7202 site 34, Levan 7202 site 33, Clayton Peak 7202 Site 26, Mount Baldy 7202 site 23 although weak at times in Manti they were using it for Event 10 For The Pageant, I would say Event 10 Is For Sanpete County.. White Pine Needs Submitted to DB and Event 10 Could be added as Sanpete Countys
Old 07-01-2013, 10:10 PM
theaton's Avatar
Member N7VU
Nice job! Do you have a control channel and any other frequencies for White Pine?
Old 07-01-2013, 10:59 PM
854.2125 was the Control Channel at the time Fairly strong 855.2125 856.2125 857.2125, 858.2125, 859.2125....its listed somewhere in FCC Cuz I had this info long befor it was online... like Bruin and bald and abajo which aint online yet but the frequencies are set...
Old 07-02-2013, 12:55 AM
Junior1970's Avatar
Event channels are assigned based on need. Event 1 through I believe 8 are used by the main counties along the Wasatch and 8 I believe is for Washington County. Event 9-16 are assigned as needed. Event 10 yesterday was being used for the chemical spill in SLC and I know that the Cruise In in Logan usually uses Event 15 and 16 over the fourth for Main Street crowd control. There is an assignment protocol per UCAN by need on those.
RS PRO-96, RS PRO-95 (2), RS PRO-94, RS PRO-93, RS PRO-2096, RS PRO-2067 (3), Uniden BC 60-XLT (3), Uniden BCT 7.
Old 07-02-2013, 6:37 AM
theaton's Avatar
Member N7VU
Default White Pine Peak
Thanks Enos. Yes those frequencies are all listed on the license. I added the White Pine site. At some point someone can find and report the Alt Channel.
