Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Utility Listening
Utility Listening - Discussions regarding monitoring government, military, aircraft, ship, and other misc communications in the HF/MW/LF bands.
  #821 (permalink)
Old 12-10-2014, 9:13 PM
Todays log:
WHISKEY-03 (Possible Navy Asset)
LIMA LIMA-56 (Navy P-C3 Aircraft)
YANKY-51 (KC-130T tanker, NY)
  #822 (permalink)
Old 12-11-2014, 12:41 PM
More Navy activity today on HFGCS with c/s NAVY ROMEO DELTA-411 calling several times requesting a radio checks on 11175.
  #823 (permalink)
Old 12-11-2014, 6:17 PM
Got LIMA LIMA-53 (US Navy P-3C aircraft) working Mainsail on HFGCS 8992 USB. Time 0010z
  #824 (permalink)
Old 05-05-2015, 4:17 PM
Cool Red River call sign heard back in the early 90's.
Originally Posted by allenmarks View Post
Red River call sign has been active of late on 11.175. Can anyone verify that this is Barksdale AFB, Louisiana?
For sure, not a guess......
I remember this call sign "Red River" being used often in the early 1990's. Another like it was "Red Cliff" used in the late 1980's.
Its doubtful anyone would know the location unless your receiver frontend was swamped by the signal for knowing it to be in the area. These aircraft HF signals can be strong from thousands of mile out depending on day to day RF conditions on the bands.
Interesting "Red River" call sign is back again. Hum... Keep listening in. If the signal bends your S-meter its a good guess the transmission is darn close hi, hi. 11.175 Mhz has always been a fun one to listen into over the years. Back in the late 80's on occasion's some more than interesting radio traffic was in the clear when someone forgot to encrypt. SWL is much like fishing. Just when you think you won't catch a thing the Big One hits Martha! >))))()*> Keep fishing and let us all know.
Just remember nation first! Radio hobby #2, always. Loose lips and ships don't go together. Be C@@L.
  #825 (permalink)
Old 06-30-2015, 10:55 AM
I monitored an EAM's last night (06-30) at approximately 0200Z that was xmitted on 11175 and also the frequencies immediately below and above. Other EAM net frequencies 8992 15016 etc only indicated the EAM as being xmitted on that particular frequency. Found this to be somewhat unusual as I have not noted it previously. Screen pic below:
f2b4e31e-4c1b-48fb-bc7c-c5dc965cbe02.png Photo by rickf_ | Photobucket
  #826 (permalink)
Old 05-03-2016, 4:05 PM
Been listening to 11175 KHz USB today and heard several EAM's with the call sign "Hoverbar". I wonder where "Hoverbar" is located? Didn't sound like he was on an aircraft, so I'm guessing he's a ground station. I thought they used to always use the call sign "Mainsail" when they were calling all stations. Maybe they've changed it to "Hoverbar".
  #827 (permalink)
Old 05-04-2016, 3:50 AM
The call sign you were hearing was Color Bar. The HFGCS ground stations, Andrews, Offutt etc now use "tactical " call signs most of the time, to identify themselves.
  #828 (permalink)
Old 05-19-2016, 7:52 PM
Hooligan's Avatar
Lightbulb
I was listening to military HF/SSB, local VHF/UHF & UHF SATCOM a lot in the 1980s & 1990s & don't remember hearing RED RIVER or RED CLIFF being used as static calls.
First you state that HF aircraft signals can be strong from thousands of miles away, but then you comment about how if a (HF) signal "bends your S-meter" being a good indication the transmitter is "darn close" is wrong. I remember plenty of times when living in both Michigan & the Washington DC area, Radio Havana Cuba would 'pin' the S-meter (60+dB over S-9) on my Kenwood R-5000. Does that mean they had remote transmit sites in SE Michigan & the DC area? For groundwave HF, basically by the time your signal meter is pegged, you ought to pretty much be able to see the transmit antenna.
RED RIVER is the static callword for the 8th AF Air Operations Center at Barksdale AFB
8th Air Force - 608th AOC & it's not classified info.
It has minimal OPSEC value, since there's an actual river called Red River running near the base, and a base chow hall is called the Red River Dining Center.
Back in the day, as a SAC base & later SAC's 8th AF HQ, Barksdale did have a somewhat major presence on HF, with separate HF transmit & receive annexes but these days, I think it's likely that the AOC's day to day, organic HF capability is one transceiver & one or two antennas on-base, of course with the ability to remotely access other US Strategic Command, USAF Global Strike Command & DOD HF nets around the world.
I am the King of All Monitoring.
  #829 (permalink)
Old 11-05-2016, 10:31 AM
Haley's Avatar
Anyone ever heard the call sign CANDYMAN? They read several EAMs 30 characters. I looked through all my lists. No luck. REDRIVER is pretty active today also. MIke
IC-R2, Pro51, (2) Pro92B, Pro96, Pro106, Pro18, Pro668, BC125AT, BC246t, BC346xt, BCD396xt, BCD436hp, Kenwood THF6A, Tecsun 380, Tecsun 880, RS DX398, RS DX392, Grundig 550PE
  #830 (permalink)
Old 06-06-2017, 7:21 PM
ridgescan's Avatar
A flurry of activity on 11175, 15016, and 8992. Motor, Bright 1-0, Skymaster, Composer, Shorthand, and four others in the mud; two females two males. As we all are, I'm ignorant to what's going on but I haven't heard this much run-on activity in a long time. Several EAMs and a half-dozen 4-group messages so far. Been monitoring for the last two hours.
Adding three more to the list-Bright 0-9, Motorist, Allowance.
BC785D to Diamond D130J @50'
IcomR71A, RS DX-160 to Wellbrook loop @50'
IcomR75,
'54 SX-88 #127 to 100' endfed wire/9:1 trans. @40'
RS Pro 2066 in truck to Larsen Tribander
  #831 (permalink)
Old 06-06-2017, 7:47 PM
From another list at Scan NewEngland
Default Skymaster Exercise 6 Jun
Guys,
Skymaster Exercise underway on 11175.0 USB as of 1600Z
Logs are from WebSDRs: TW (Univ of Twente), NH (New Hampshire), CN (Edmonton Alberta), HI (Hawaii),
((Times UTC, Freqs KHz))
11175.0 1459Z Skull 82 (B-52H 2nd BW/20th BS, Barksdale AFB, LA) USB calling for R/C. (NH) o
11175.0 1542Z (call missed) 21 (prob B-52) USB R/C w/Red River (608th Air Operations Center (AOC) Barksdale AFB LA) then asks for check on CONR-2. (NH)
11175.0 1543Z Abrasion (TACAMO/ABNCP) USB calling Genetics w/no response. (NH)
11175.0 1544Z Kirk 62 (sounds like) USB calling Mainsail. (NH)
11175.0 1547Z Genetics USB w/Abrasion w/authentication procedures to enter the net. (CN)
11175.0 1555Z Lure 71 (sounds like) USB calling Mainsail. Answered by Genetics but Lure 71 not respond. (CN)
11175.0 1640Z Kirk 61 (sounds like) USB calling Skymaster. (CN)
11175.0 1641Z Genetics USB w/EAM W26EYJ (30 chars). (CN)
11175.0 1646Z Reach 410 USB calling Mainsail. (CN)
11175.0 1647Z Clump 10 USB calling Mainsail. (CN)
11175.0 1647Z Reach 410 USB calling any stn. (CN)
11175.0 1648Z Black Day USB w/Kirk 61 w/msg: 8H21. (CN).
11175.0 1648Z Kirk 63 USB calling Skymaster. Answered by Black Day. (CN)
11175.0 1649Z Clump 08 USB calling Skymaster. (CN)
11175.0/08992.0 1657Z Genetics USB w/EAM 43IQ56 (30 chars). Repeated at 1700Z. (CN)
11175.0 1649Z Black Day USB w/EAM 43IQ56 (30 Chars). (CN) (HI) & (TW).
Ron (mdmonitor1@verizon.net)
Baltimore MD (390747N 763711W)
VHF/UHF: BC-895XLT/RS Pro-2045 w/Diamond D-130J discone (in attic)
Various WebSDRs & Live ATC
  #832 (permalink)
Old 06-06-2017, 8:34 PM
Default High EAM and other HF traffic- unusual freqs
6903 KHZ - Lot's of activity on this unusual freq with EAM's here from 8 Uniform Delta", plus lot's of other traffic on usual global freqs tonight. 00:55UTC have 6778KHz with different EAM voice as well
"Allowance", "Midas", other heard.
Is this just comm exercise?
  #833 (permalink)
Old 06-06-2017, 8:56 PM
ridgescan's Avatar
Most likely, seeing Jack's post. Been hearing it heavy here for last four hours.
IcomR75,
  #834 (permalink)
Old 06-06-2017, 9:00 PM
OK. But why all the new freqs like 6778/6833/6903/7703?
  #835 (permalink)
Old 06-06-2017, 9:20 PM
ridgescan's Avatar
Good question as I only know of 4724, 6397, 8992, 11175, 11220, 11244, and 15016kHz. You caught some unusual ones there. How'd you do it-SDR? BTW the activity seems to have gone way down now.
IcomR75,
  #836 (permalink)
Old 06-06-2017, 9:26 PM
Yes. Was looking at pirate radio 6500-7000 KHz on SDR. USAF freq activity down now here too so guess it was just exercise.
If you've never heard HF pirates before, give a listen on 6925-6975 most evenings, usually USB or AM.
6940KHz USB active right now. "Clever Name Radio" is on. Playing a relay of "Cool AM radio". A station from Netherlands.
  #837 (permalink)
Old 11-07-2017, 11:10 AM
ridgescan's Avatar
There's been a lot of long-winded EAMs last couple days up to 96 characters (my observations). Also activity on 11232 but haven't got a read on that yet.
IcomR75,
  #838 (permalink)
Old 11-07-2017, 11:26 AM
Romak3's Avatar
I was just thinking last night how they have really been active. I have scanner to listen too the localPD/FD with 311 popped in. I first noticed this past Sunday how they have been going so much.
ICOM R71 A-A-E -- R20 -- Sangean 803a
Par EF-SWL
Whistler/Uniden
  #839 (permalink)
Old 11-07-2017, 5:57 PM
Default 8.992 KHz.
About every half hour I am hearing a transmission sending letters by voice. The audio sounds like the gain is set way too high and causing distortion and sort of a room echo effect. It is happening about 14 past the hour and about 44 past the hour.
The title should be 8.992 MHz.
Jim
  #840 (permalink)
Old 11-07-2017, 6:22 PM
Mark's Avatar
Yeah you guys are catching end of Global Thunder 18 on HF.
Been busy last 5 days or so.
Your echo is most likely you receiving multiple worldwide stations on same freq but slight time delay due to distances between broadcast stations.
USSTRATCOM works with allies during Global Thunder 18 > U.S. Strategic Command > News Article View
'Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy; its inherent virtue is the equal sharing of misery." - Winston Churchill
