Token
Right now there is a Chinese 4x4 modem up on 4283 kHz LSB, 7553 kHz LSB, and 9153 kHz LSB. Normally this signal is seen before the M95 numbers station comes up on the same frequencies (in CW). And typically V26 (in USB) follows these signals. That means that in the next 20 to 50 minutes (from now, 1309) both M95 and V26 should be up on these freqs.
T!
T!
