V24 and M94 observations for Nov and Dec of 2011, and new schedule chart
Token
One of the several numbers stations I monitor from time to time is the Korean language V24 and CW station M94. Both of these stations are transmitted from the same source. V24 most often uses North Korean music for a lead-in, but the transmit source is South Korean.
I post periodic updates on this station to both the Enigma 2000 group and to the UDXF Utilities monitoring group. The following is my update posted Dec 31, 2011, to both of those groups. As part of these updates I normally produce a chart of past performance to use for future transmission predictions.
V24 and M94 have once again undergone some fairly substantial changes in frequencies and schedule.
Starting November 6, 2011, I noticed a new frequency in use by V24, 6310 kHz. Since a couple weeks before that date I have not seen 6730 or 6330 kHz in use. My assumption is that about November 1, 2011, the frequencies of 6730 kHz and 6330 kHz were discontinued and the new frequency of 6310 kHz was added.
The total number of messages each month have not reduced by any appreciable number, so it appears the activity that was on 6730 and 6330 kHz has shifted to the still active freqs. For the most part the 6730 kHz activity appears to have shifted to 6310 kHz and the former 6330 kHz activity has shifted to the remaining freqs, for example the 6330 kHz M94 slots have moved to 5715 kHz, but on the same days and at the same times as when on 6330 kHz.
Fewer and fewer 4f format messages are being sent, the vast majority are now 5f.
The latest schedule of V24 and M94 transmissions can be found here:
http://token_radio.home.mchsi.com/V24_M94_latest_sched.JPG
This schedule is still somewhat tentative and in work, but should be fairly accurate. But notice I am no longer including the version number or date in the URL, the intent is to keep the most current version at that URL from now on.
Note that the schedule contains a time column not seen on previous schedules I made, in this case 1240 UTC. There have been a couple of transmissions in this time slot so I have included it on the schedule, but I will remove that column if these transmission do not repeat in the future. In the past V24 has used XX20 and XX40 time slots, but never for very long other than the 1620 time slot, which was used for over a year. In fact a few times it has used the XX20 and XX40 before the normal 1200 UTC start time.
T!
Logs:
November receptions of V24:
11/04/2011, 1430 UTC, 5715 kHz, AM, V24, YL KK 5f
11/04/2011, 1500 UTC, 4900 kHz, AM, V24, YL KK 5f
11/05/2011, 1400 UTC, 5115 kHz, AM, V24, YL KK 5f
11/06/2011, 1400 UTC, 5115 kHz, AM, V24, YL KK 5f
11/06/2011, 1530 UTC, 6310 kHz, AM, V24, YL KK 5f
11/06/2011, 1630 UTC, 6310 kHz, AM, V24, YL KK 5f
11/07/2011, 1300 UTC, 6310 kHz, AM, V24, YL KK 5f
11/09/2011, 1330 UTC, 6310 kHz, AM, V24, YL KK 5f
11/10/2011, 1430 UTC, 5715 kHz, AM, V24, YL KK 5f
11/10/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
11/11/2011, 1430 UTC, 5715 kHz, AM, V24, YL KK 5f
11/11/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
11/11/2011, 1530 UTC, 5715 kHz, AM, V24, YL KK 5f
11/11/2011, 1600 UTC, 6215 kHz, AM, V24, YL KK 4f
11/11/2011, 1630 UTC, 5715 kHz, AM, V24, YL KK 4f
11/19/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
11/19/2011, 1630 UTC, 6310 kHz, AM, V24, YL KK 5f
11/20/2011, 1430 UTC, 5715 kHz, AM, V24, YL KK 5f
11/20/2011, 1500 UTC, 5115 kHz, AM, V24, YL KK 5f
11/20/2011, 1630 UTC, 6310 kHz, AM, V24, YL KK 5f
11/24/2011, 1300 UTC, 5715 kHz, AM, V24, YL KK 5f
11/24/2011, 1330 UTC, 6310 kHz, AM, V24, YL KK 5f
11/24/2011, 1530 UTC, 4600 kHz, AM, V24, YL KK 5f
11/25/2011, 1530 UTC, 4600 kHz, AM, V24, YL KK 5f
11/26/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
11/27/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
11/28/2011, 1300 UTC, 6310 kHz, AM, V24, YL KK 5f
November receptions of M94
11/10/2011, 1400 UTC, 5715 kHz, MCW, M94, ID 935
11/27/2011, 1400 UTC, 5715 kHz, MCW, M94, ID 935
December receptions of V24
12/02/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
12/02/2011, 1530 UTC, 5115 kHz, AM, V24, YL KK 5f
12/03/2011, 1430 UTC, 5715 kHz, AM, V24, YL KK 5f
12/03/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
12/03/2011, 1530 UTC, 5115 kHz, AM, V24, YL KK 5f
12/04/2011, 1430 UTC, 5715 kHz, AM, V24, YL KK 5f
12/04/2011, 1500 UTC, 4900 kHz, AM, V24, YL KK 5f
12/09/2011, 1330 UTC, 6310 kHz, AM, V24, YL KK 5f
12/09/2011, 1530 UTC, 4600 kHz, AM, V24, YL KK 4f
12/10/2011, 1330 UTC, 6310 kHz, AM, V24, YL KK 5f
12/10/2011, 1430 UTC, 5715 kHz, AM, V24, YL KK 5f
12/10/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
12/10/2011, 1630 UTC, 5115 kHz, AM, V24, YL KK 4f
12/11/2011, 1430 UTC, 5715 kHz, AM, V24, YL KK 5f
12/11/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
12/11/2011, 1530 UTC, 5715 kHz, AM, V24, YL KK 5f
12/11/2011, 1630 UTC, 5115 kHz, AM, V24, YL KK 4f
12/15/2011, 1430 UTC, 6310 kHz, AM, V24, YL KK 5f
12/16/2011, 1430 UTC, 6310 kHz, AM, V24, YL KK 5f
12/16/2011, 1500 UTC, 4900 kHz, AM, V24, YL KK 5f
12/17/2011, 1500 UTC, 4900 kHz, AM, V24, YL KK 5f
12/17/2011, 1530 UTC, 5115 kHz, AM, V24, YL KK 5f
12/18/2011, 1500 UTC, 6215 kHz, AM, V24, YL KK 5f
12/18/2011, 1530 UTC, 5115 kHz, AM, V24, YL KK 5f
12/19/2011, 1300 UTC, 5715 kHz, AM, V24, YL KK 5f
12/19/2011, 1330 UTC, 6310 kHz, AM, V24, YL KK 4f
12/23/2011, 1330 UTC, 6310 kHz, AM, V24, YL KK 5f
12/23/2011, 1630 UTC, 5115 kHz, AM, V24, YL KK 4f
12/24/2011, 1330 UTC, 6310 kHz, AM, V24, YL KK 5f
12/24/2011, 1530 UTC, 4600 kHz, AM, V24, YL KK 4f
12/25/2011, 1240 UTC, 5715 kHz, AM, V24, YL KK 5f
12/25/2011, 1300 UTC, 5715 kHz, AM, V24, YL KK 5f
12/25/2011, 1530 UTC, 4600 kHz, AM, V24, YL KK 4f
12/31/2011, 1500 UTC, 5115 kHz, AM, V24, YL KK 5f
12/18/2011, 1530 UTC, 4900 kHz, AM, V24, YL KK 5f
December receptions of M94
12/10/2011, 1400 UTC, 5715 kHz, MCW, M94, ID 935
12/11/2011, 1400 UTC, 5715 kHz, MCW, M94, ID 935
