Montpelier PD gone Digital??
Blackink
Central Vermont
I haven't heard the Montpelier PD for about a week now on frequency: 460.0500 Tone 118.8Hz.
Wondering if anyone has heard if they've switched to digital?
Something must be going on........
Blackink
Central Vermont
I have more questions:
1) Can an analog and a digital transmission be on the same frequency?
2) How would I find out more info on the digital system MPD is using?
Thanks............
Thunderknight
Bletchley Park
To answer your question #1, yes they can, but not at the same time. But some units can be digital and some analog. If programmed for that, the radios will receive both (called mixed mode).
Try programming your scanner for the same frequency but no tone (carrier squelch). If you hear 1-5 second transmissions of "noise", that is probably them in digital mode.
If digital they could be encrypted too. Only way to know (besides a post from someone who already knows) would be a digital scanner or something like DSD (software). If they are encrypted, you won't be able to listen.
Blackink
Central Vermont
ecps92 mentioned Dual-Mode (mixed mode) so you both are probably correct there.
I'd be surprised if they were encrypted (and I hope NOT!).
I'll try the no tone (carrier squelch) and listen....
Thanks for the help.....
Blackink
Central Vermont
Well, I no sooner set my CTCSS/DCS to OFF on Frequency 460.0500 and started getting what sounds like static/buzzing for about 3-5 seconds.
The amount of times that I'm hearing this sound would be comparable to if they were talking on their radios. Sometimes it's every couple of minutes, sometimes I don't hear anything for a few minutes and then when I do hear it, it can last for what seems like the length they would be talking on the radio: 2 seconds to 30 seconds, average time seems to be about 3-5 seconds.
Does that sound like it's a digital frequency to you?
If so, how would I find out if it's Phase I, Phase II, or Encrypted?
ecps92
Taxachusetts
Phase II is for a trunked system only.
The only way to note ENC is to listen
Depending on make/model, some scanners skip over ENC P25
Thunderknight
Bletchley Park
The easiest way is to buy a digital scanner :)
If you want to experiment, read up on DSD / DSDPlus as a cheaper (but less portable) method.
Blackink
Central Vermont
So when I buy a digital scanner and program in the Montpelier PD on frequency 460.0500, which seems to be the frequency they are transmitting on, would I put the tone on "SEARCH" to find out what tone they are using?
I wouldn't think they would be transmitting on that frequency using the same tone they were using before while on Analog: 118.8Hz, correct?
ecps92
Taxachusetts
A Digital Scanner would be programmed for Tone Search and Auto for the mode, it will generally then display the PL/DPL if on Analog and the NAC if on P25
Leaving it in Automode will also allow you to hear them when/if they use Analog PL
Thunderknight
Bletchley Park
Well it's a NAC search, not a tone search. NAC is used for P25 and is just some data bits in the P25 data stream. Same operational concept as a tone, but it's technically very different.
But you are correct, they would not have a 118.8 tone on digital (they would be no "tone" for digital, but there would be a NAC).
Blackink
Central Vermont
Thanks.....
Blackink
Central Vermont
Thanks for the clarification, much appreciated!!
jimlawrence
You're welcome, Steve.
Let us know if you get a NAC for them, please.
I'm also wondering if Barre City PD has gone P-25, too? Do you listen to them, Steve?
