Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Vertex Standard
Vertex Standard Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 03-09-2009, 01:52 PM
renze8173's Avatar
Default Vertex Standard
Any Vertex Standard Owners Out There?
YOUR'E NEVER TO GOOD TO SCOOP POO!!
Old 03-09-2009, 10:33 PM
firefighter89's Avatar
I've got a Vertex VX-354 VHF portable.
Old 03-10-2009, 12:36 AM
RodStrong's Avatar
Own and still use FTL mobiles, and use a VX-3200 every day. Used a VX-500 for several years.
Old 03-10-2009, 11:30 AM
I have the VX-180, Vx-354, and my fav the Vertex VX-900 also for base station use i have the FTL-2011, All of these units have excellent receive and loud audio. The 180 and vx-354 i have set up for All-call tone outs and work very well.
I was interested to see opinions on any users of the VX-824 and 829 models on how well they perform.
Thanks!
Old 03-10-2009, 07:20 PM
James04TJ's Avatar
In the past I used a VX-3200, VX-10's, and also a VXR-7000. No complaints about any of them.
Old 03-11-2009, 12:13 AM
I have 2 FTL7011-99, 1 FTL2011-99, and a VX(?)3200 vhf. Happy with all of them.
Old 03-11-2009, 09:12 AM
renze8173's Avatar
I Swapped Out The Motorola Cm300 In My Truck For A Vx-2200 Just For Kicks. Wow, I Like It Much Better Than The Cm300 BecAuse Of The Price, Loudness Of The Audio, And 128 Channels Vs. 32. Also More User- Friendly. And The Programming Software Is Much Cheaper!!!!!!!!!!!!!!!!!
Old 03-11-2009, 12:13 PM
mm mm is offline
I have 3 FTL-X011's one 4 channel FTL-1011 converted to 6 meters with a front panel programmable control head and 2 of the 99 channel FTL-2011's converted to 220 MHz.
Good radios especially price wise.
Old 03-11-2009, 03:27 PM
khubbard's Avatar
I have a vx180 vhf, vx427 uhf, vx160 uhf, and vx427 uhf ltr. I used to have a vx6000 vhf and vx4000 uhf setup for dual band but sold it. I also use a vx6000 vhf as a base radio for dispatching trucks everyday
Keith
Vertex VX-427A uhf LTR
Vertex VX-160 uhf
Vertex VX-180 vhf
Vertex VX-427 uhf
Kenwood TK-880 uhf
Old 03-12-2009, 08:56 AM
I bought (3) VX 3200 and (1) VX10 they should be here any day, I will post if they are good or not
Also does anyone know if I can use (2) VX 3200 and convert them as a repeater?
GMRS user
Old 03-12-2009, 09:56 PM
I'm looking hard at a new VX4207 series, so I might be a Vertex owner soon. Also looking hard at the HYT TM-800. They are both a lot of radio for the money.
Old 03-13-2009, 07:04 PM
Send a message via Yahoo to wkredick
If you need MDC1200,the TM800 mobile does it.Both are decent mobiles and channel heavy.
You can also do 2/5 tones decode/encode on either mobile.
Old 03-13-2009, 08:35 PM
Send a message via AIM to fineshot1
If possible can you please pm me with info or a link(don't want to hijack this thread) on converting
the FTL-2011 to the 220 ham band ?
fineshot1
NJ USA
Old 03-14-2009, 05:41 AM
DiGiTaLD's Avatar
I have a VX-180 UHF that I use daily for work. The only thing I don't like about it is how the batteries tend to die on it. More often than not, it will just stop transmitting without ever giving you a low battery indication while receiving. Sometimes it will flash the red light at me for a while before it dies, but usually it doesn't. I always have an extra battery, so its not that big of a deal, but a little advance warning would be nice.
Otherwise, great radio.
"...interoperability will always be a pain because the people who are supposed to be working together want nothing to do with each other until something really bad happens." -shell6
Old 03-21-2009, 11:15 AM
W9RXR's Avatar
I have a couple VX-10 VHF and a couple VX-10 UHF and a VXA-100 (aircraft). I also have a couple FT-50 amateur dual-band radios. It's handy being able to use the same battery packs, speaker mics, and other accessories on all of these radios.
Old 03-27-2009, 09:34 AM
MississippiPI's Avatar
I have ordered a VX-2200 VHF radio to install in my car, can't wait to get it.
Be Safe
MississippiPi
Copiah County, MS.
Old 03-29-2009, 11:53 AM
mm mm is offline
FINEshot1, the 220 conversion is still in the document stage.
The converted radio is being used by it's owner but I should have it back for a week to take some pictures.
Or the same guy may give me a second FTL to convert and then I can take some good pictures of this conversion, step by step, which is something that I didn't do with the first radio.
I did a similar conversion a few years back for the MT1000 low band to 6 meter ham and the pictures and documentation should be similar to that project, the only difference is that the FTL will have more pictures and documentation related to converting the transmitter and receiver, both which required some work.
The hardest part, like my MT1000 documentation was removing the VCO but even this is not so bad once you get by removing it from the radio and from its sub case.
All in all it's a nice conversion, the original FTL-2011 transmitter stage produces 24 watts on 220 with only some capacitor changes.
The receiver does around .28 uv for 12dB sinad with some core changes from ferrite to brass in the pre-selector filter.
Old 03-29-2009, 07:33 PM
Using a VX924 VHF right now,great audio on this radio.Relatively new to Vertex here myself and am impressed by the 920 series.
I hope to save and get a VX824 in UHF for listening to all the UHF around me.
Old 03-29-2009, 08:17 PM
OK - Thank you mm for that info. I googled and my eyes went blurry looking for this info and never
found it and that explains why. If you get some mod doc put together I would appreciate a pm or
email. Thanks again...
fineshot1
NJ USA
Old 04-02-2009, 08:37 AM
Default Vx-510
I Have VX-510's and VX-500's on 10m and 6m it's just a software hack and a little vco tuning
N2RLD
Similar Threads
FS: Vertex Standard VX-180 VHF handheld with extras. wp3539 Old Classifieds Archives 2 09-02-2008 09:31 PM
(vertex) Standard GX5800 and HX582T Programming StormChaserFLA LTR Trunking 4 06-22-2007 08:38 AM
Vertex Standard VX-160/VX-180 AndrewJohnson General Scanning Forum 3 10-26-2006 09:52 AM
Vertex Standard unlisted Tavern Archives 13 05-24-2006 11:06 PM
Vertex Standard offering APCO-25 Portables and Mobiles FuelForFire Project 25 Technologies 5 02-12-2006 12:27 AM
