Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Vertex Standard
Vertex Standard Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 05-07-2009, 08:32 AM
Question Need help programing VX 160
I have a vx160, usb programing cable, ce44 software and laptop that is running on windows XP. I have reduced the baud rate to 1200, reduced the trans/rec buffers to minimum and tried with and without the FIFO buffers on, but can not get he radio to upload. I have gotten the program to bounce between "Please wait" and "retry", but eventually goes to check to see if you connected to the com port. Is there a certain procedure or setting that I have missed? Any imput or help would be appreciated.
Old 06-08-2009, 04:09 PM
KC2OBW's Avatar
Send a message via AIM to KC2OBW
I am having the same issue..I ran read the radio with out a problem but trying to write the radio is the issue..if you seem to get it work please let me know.
Old 06-08-2009, 05:41 PM
ambdrvr's Avatar
Send a message via MSN to ambdrvr Send a message via Yahoo to ambdrvr
Default Vertex VX-160
Hello,
If I remember correctly the CE44 software is DOS based software and probably doesn't have very good support for the USB cable that you are using. I don't really have an answer for you as I have not used the USB cables, always the DB9 cable. Maybe you can try to rename your USB port to port 1 (that should be what the software is looking for) and try it that way. If I am correct and CE44 is DOS, maybe try using an older computer with Win98 on it.
That's just my 2 cents worth. Hope it helps.
Ambdrvr
Old 06-08-2009, 07:09 PM
KC2OBW's Avatar
Thanks for your reply ambdrvr..they have a windows and a dos version of CE-44..I can currently read the radio with no problem..but how ever when I write the radio it starts writing, and half way through it downloading it hiccups and doesn't program. My VX-354 which uses CE-86 I use a USB cable for and it works..I only get issues some times, I just have to restart the program and its fine, and as for using a DB9 I wish I could but my laptop does not support that.
Old 06-18-2009, 03:06 PM
I hade the same problem but found a new ver of ce-44 for windows vista and it works great with xp..If there was a place to upload software I would share it but cant seem to find a spot to upload..if I ever find that site again I will share It..well found it and here it is...
hxxp://www.radioscanner.ru/files/vertex/file7294
Old 06-19-2009, 09:17 PM
KC2OBW's Avatar
Hmmm I wonder if it will work for XP if its for vista..well I downloaded..when I get a chance I'll run home and grab my 180 and see if it works
Old 06-24-2009, 11:11 PM
KC2OBW's Avatar
Tried it a few days ago and was able to read and write my 180 with no issues.
Old 08-08-2009, 10:05 PM
Send a message via Yahoo to undertakeru
I have had the same problem with windows vista, Thank you for the Vista version C44 software
Similar Threads
RS PRO 160 & 162 Being Discontinued PRO64 Radio Shack Scanners 59 07-17-2009 10:09 PM
FS: Vx 3200 Uhf (3) 125 Old Classifieds Archives 16 02-23-2009 11:56 AM
PRO 160 & 163: Quick Reviews KC2GVX Radio Shack Scanners 0 12-19-2008 12:08 PM
Scanner Programing BillHolt555 Tennessee Radio Discussion Forum 20 11-19-2007 05:59 PM
Wanted: Programing Southtown800 Old Classifieds Archives 1 11-06-2005 01:52 AM
