Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Vertex Standard
Vertex Standard Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 05-29-2009, 04:10 PM
Default vx-10 vhf
Hello, I just picked up some vx-10 vhf models and would like to find the programing software if someone knows where to get it. I called vertex and they said it is not available anymore . The software is CE-14, and also is the programing cable the standard 4 ring 1/8" plug.
Rich
KB0ZGY
Old 05-29-2009, 04:15 PM
W9RXR's Avatar
Lead Wiki Manager
You can probably find the cable on eBay or buy one from RT Systems (RT Systems Radio Programming Software). The Yaesu FT-50 cable will do the job.
Search around on the web for the program. It's a DOS program. You'll need a computer that runs DOS or that you can boot into DOS. Running the program from a DOS box in Windows won't work.
Because you will be running in DOS, don't plan on using a USB port on the computer. You'll probably need a real serial port.
Old 05-31-2009, 07:12 PM
silverbk's Avatar
You can program that model through the keypad. You can make a dongle out of aluminum foil.
Similar Threads
FS: Motorola SP50 VHF 10 Channel. KX5MOT Old Classifieds Archives 5 02-25-2009 03:27 PM
Fs: Vhf Xts-5000 (fpp) bilat Old Classifieds Archives 1 03-24-2008 02:41 AM
Frequency spacing kennyloatman Uniden Scanners 3 02-02-2008 07:51 AM
FS:4 KPC VHF portables and 1 MPA VHF portable SuperProbie Old Classifieds Archives 2 12-20-2007 07:20 PM
Maxon SM4150m VHF 16 ch 40 Watt /Sp2550m 10 ch walkie mrgadjetx Old Classifieds Archives 2 11-21-2007 12:04 PM
