Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Vertex Standard
Vertex Standard Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 06-18-2009, 02:52 PM
Default Programing
I have 2 vertex standard radios one is vx-132 and the other is vx-160 I'm trying to program 2 of the frequencies from the 132 to the 160 but seem to be having trouble I can transmit from the 132 and receive on the 160 but I cant transmit from the 160 to 132 I'm real green when It come to this stuff and maybe just have some setting that are wrong..I would really appreciate any advice from anyone...
Thank You
Old 06-20-2009, 11:45 PM
Ray_Air's Avatar
Thank You
Here are a few tips. Make sure the software is the same for both. If so, always read a radio first and then edit the programming information. Never just start programming from the programming screen. In the beginning I messed up one of my Vertex radios because one of them didn't have 12.5 KHz spacing in the hardware, just 5 and 10KHz spacing.
Ø
Motorola Systems Saber Net
0249AF6AB3915CD2
Old 06-21-2009, 11:52 AM
Thanks but the vx132 and the vx160 use different software to program the radios...The 160 use ce-44 and the 130 use ce-74..the frequency I'm trying to program on the 160 is 151.895 witch can be programmed to It but it also has a pwr2 and a code 058-047 writhen on the same line beside the frequency...on the 160 I don't have this option...I know absolutely nothing when It come this stuff I'm so green you can mistake me for a blade of grass any help would be greatly appreciated.
Old 06-22-2009, 09:24 AM
Sounds like that "code" could be the problem. If the 160 does not have any codes enabled, then try to disable that code on the 132. Or you could try to duplicate the same code on the 160. You also want the enc and dec codes the same. If one is 047, make the other one the same.
Similar Threads
RE: Programing a Uniden Bearcat BC246T TrunkTracker III Scanner JimBobTerp Pennsylvania Radio Discussion Forum 0 05-28-2009 01:00 AM
RE: Programing a Uniden Bearcat BC246T TrunkTracker III Scanner JimBobTerp Uniden Scanners 1 05-27-2009 08:30 PM
butel arc programing beiniam Scanner Programming Software 2 01-19-2008 01:10 PM
Motorola Programing RyEn24 Old Classifieds Archives 2 10-25-2006 10:26 AM
Programing Question vegasdewey Nevada Radio Discussion Forum 6 03-13-2006 12:34 AM
