Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Vertex Standard
Vertex Standard - Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 04-24-2013, 8:32 AM
wa2chj's Avatar
Question Vertex CE 115 (VX-450 Series) Question
I have been using CE 115 (ver 1.06) to program Vertex VX-459 radios for a while. Today, when I opened CE 115, the TAG column in the Main Channel view window is gone.
It is checked in the View menu, and shows in both the Group column and in the Change Display Mode view if you click in the Channel Info box. It is only missing from the main view, and as I said above, it IS checked in the View, Main Items Menu.
I've looked all through the software and cannot find anything else that's changed, and I didn't change anything that I know of.
It doesn't matter if I open an existing file, or start a new one, the TAG column is gone.
Anyone else have this problem...or know of a way to correct it?
Old 04-24-2013, 12:10 PM
TRNcommLLC's Avatar
Goto "C:\Program Files\Vertex Standard\CE115" then delete "CE115.xml" and restart ce115.exe and load a file.
You will be back to the original look when you first installed it.
John
Old 04-24-2013, 12:32 PM
wa2chj's Avatar
John, TRNcommLLC, worked one-on-one with me to work this out.
His fix worked perfectly. This was a very weird problem to begin with.
THANKS, John!
Old 04-24-2013, 3:11 PM
TRNcommLLC's Avatar
Your Welcome... anytime!
Tags
ce 115, vx-450, vx-459
