Vertex VX-4200 MDC1200
krantzc93
Mckeesport
Hi, I am doing a little project for my municipal PD (Non-Profit). their radios currently have MDC-1200 for their identifiers. In the actual physical codeplug Under "SIGNALING - No" Option #2 (MDC1200) is selected and available. How ever, when I ever go to the settings tab "signaling" - "MDC1200" is unselectable (Grayed out) to modify. I figured it was my Software being out of date and needed the newer software -so I purchased and downloaded the most up to date software, still unselectable. Do you know why this would be??? the radio is a mobile - Vertex Standard VX-4200 series Firmware: 1.77 - Software CE59 V 4.04. Like I said the radio already has an MDC1200 ID in it which they currently use. They requested me to update some channels for them and I need to do it on multiple radios and it would be a lot easier and less time consuming to have the codeplug pre-made for each unit apposed to reading each device and modifying the code on location.
WISCOMM
Elm Grove, WI
VSOL is showing current FW as 2.22 and CE59 as 4.01.
I can take a peek at the software on Monday when back in the office and see if something jumps out at me.
Craig
TRNcommLLC
Monongahela, PA
MDC1200 is only for VX820/920 series under that programming software (CE59).
If you want to do MDC1200 you need the VME-100 add on board and the software (CE73) to program the VME-100.
MDC1200 is not standard in that radio that's why it's grayed out. It's just for VX820 and VX920 series radios.
Hope this helps.
John
krantzc93
Mckeesport
worked out on its own
I was so lucky that loading the code plug in each mobile didnt even effect the id that was in each radio! Didnt have to change anything but thank you!
