Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Vertex Standard
Vertex Standard - Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 02-08-2014, 10:09 PM
krantzc93's Avatar
Default Vertex VX-4200 MDC1200
Hi, I am doing a little project for my municipal PD (Non-Profit). their radios currently have MDC-1200 for their identifiers. In the actual physical codeplug Under "SIGNALING - No" Option #2 (MDC1200) is selected and available. How ever, when I ever go to the settings tab "signaling" - "MDC1200" is unselectable (Grayed out) to modify. I figured it was my Software being out of date and needed the newer software -so I purchased and downloaded the most up to date software, still unselectable. Do you know why this would be??? the radio is a mobile - Vertex Standard VX-4200 series Firmware: 1.77 - Software CE59 V 4.04. Like I said the radio already has an MDC1200 ID in it which they currently use. They requested me to update some channels for them and I need to do it on multiple radios and it would be a lot easier and less time consuming to have the codeplug pre-made for each unit apposed to reading each device and modifying the code on location.
Old 02-09-2014, 9:36 AM
VSOL is showing current FW as 2.22 and CE59 as 4.01.
I can take a peek at the software on Monday when back in the office and see if something jumps out at me.
Craig
http://www.ShopWiscomm.com
Old 02-09-2014, 9:58 AM
TRNcommLLC's Avatar
MDC1200 is only for VX820/920 series under that programming software (CE59).
If you want to do MDC1200 you need the VME-100 add on board and the software (CE73) to program the VME-100.
MDC1200 is not standard in that radio that's why it's grayed out. It's just for VX820 and VX920 series radios.
Hope this helps.
John
Old 04-17-2014, 11:54 PM
krantzc93's Avatar
Default worked out on its own
I was so lucky that loading the code plug in each mobile didnt even effect the id that was in each radio! Didnt have to change anything but thank you!
