Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Vertex Standard
Vertex Standard Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 04-25-2014, 10:35 PM
Default VX900 LCD Display Problem
I have a VX900 that i had to remove the LCD and inter connector when i reinstalled the LCD the display is now illegible it did wrk fine before i diassembled. i have replace both the interconnect and LCD with no change. all other function and transmit are fine. anyone have any experience with this type problem. the inter connector between the board and LCD is a rubber they material.
Old 04-26-2014, 10:02 PM
The 'rubber' like material has micro fibers that transfer the electrical signals to the LCD.
This 'rubber' has little dark sports that are the fibers.
If it is not correctly installed then you get these problems.
Why did you have to take it apart?
Make sure that the area that the location where the 'rubber' goes is truly clean, use a soft tooth brush and LITELY clean the area and then when you install the 'rubber' make sure that the little dark sports are facing to both the board and the LCD.
Also the LCD only goes in one way.
Give that a try.
Old 04-26-2014, 10:11 PM
Default vx-900
had to repair broken screw at remote mic connection. tried your sugestion with no change
Old 04-26-2014, 10:22 PM
Default Re: VX900 LCD Display Problem
I always install a new zebra connector when I replace a bad or cracked lcd.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Old 04-27-2014, 12:46 PM
did replace connector with same results. the small character look ok but the large character are circles with line thru them.
Old 04-28-2014, 6:38 PM
The VX-900 are very sensitive when aligning up the LCD, it is best to power up the radio while making the adjustments to the LCD, while tightening the screws.
