Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Vertex Standard
Vertex Standard - Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 08-03-2014, 10:51 PM
Question vertex vx-160u
What program do I need for the VX-160U?
Don't care about the narrow banding.
Old 08-04-2014, 7:32 AM
wa2chj's Avatar
Post
Vertex CE44 for VX160/180 Series.
Old 08-04-2014, 12:42 PM
Thumbs up
Thanks!
Old 08-04-2014, 1:01 PM
what windows program do I need to run the ce44 on?
Old 08-04-2014, 1:39 PM
never mind. went to my old desktop that has xp. program working now.
Old 08-05-2014, 7:40 AM
wa2chj's Avatar
Post
Just FYI, CE44 runs on everything I've ever tried it on. XP, Vista, Windows 7, and Windows 8. If you use a computer without a serial port and use a USB adapter, sometimes the drivers can be an issue as can finding the right COM port, but it will work with just about anything.
Old 08-05-2014, 8:08 AM
Thumbs up Thanks!
Thanks, I will reinstall the program on my laptop with Win.8. since all my other vertex programs are on it as well.
Old 08-05-2014, 5:39 PM
Exclamation lost
for some reason I cannot get this program to work at all. I install it and then cannot find the icon to click to open the program at all. Tried installing compat. mode for Windows XP, Vista, and 8. still nothing.
Old 08-06-2014, 7:52 AM
wa2chj's Avatar
Post
It's not like most other programs. It doesn't put an icon on your desk top automatically. You have to go into the folder - usually in Programs - and right click on the Application file that shows the little Vertex HT icon. Then select "send to" and send it to your desk top. The icon will then appear on your desk top and you should be all set. Alternatively, you can just double click on the application icon and start the program from the Programs folder. Either way I'll bet the program installed properly, it just doesn't put the icon on the desk top, but that's the way it is.
Old 08-06-2014, 9:36 PM
Default still no luck
Picture of the file ce44 after I open it.
Old 08-07-2014, 7:35 AM
wa2chj's Avatar
Post
That's where it puts the data files, and where it will put any radio plugs you program. The actual program itself is in a folder under "Program Files" or "Program Files (x86)", I think. I'm at work right now, so I can't look and see where it puts them. IIRC, it creates a file folder called "Vertex" or "CE86" and puts the program in there. I'll check when I get home tonight. Since it created the data files and folder, the rest probably is there as well. I have the programs here at work, but have them installed on a USB drive, so it's a non-standard installation.
Old 08-07-2014, 3:00 PM
Default Okay
I looked around on my system, and took a pic of both program file locations so you can see what I see.
Only place I even see anything with vertex is under windows with the file name "vertex standard." all 3 window shots are posted here.
Old 08-07-2014, 7:04 PM
push your windows key then click on programs skroll down to vertex or vertex standard and you will find the progrom.
click on it and it will open just fine.
Nice and easy. very simple
Old 08-07-2014, 7:33 PM
Thumbs down lol
thanks but that's no help at all. lol only "vertex" or "vertex standard" file in my whole computer system is in the C: were is shows the files program and program x86. and under that area of Apps I am only showing my 2 vx programs one for the 2200 mobile and the vx350 program. no ce44.
Old 08-08-2014, 7:06 AM
wa2chj's Avatar
Post
OK. I never made it home in time last night to look on that computer. I'll get to it over the weekend. When you installed CE44, did you get any errors...or did it got to the "Finish" screen?
Old 08-13-2014, 6:53 AM
wa2chj's Avatar
Post
OK, finally got a chance to look at my home computer, The path to the .exe file is as follows:
Computer
OS C:
Vertex Standard
CE44 for Windows
ce44win.exe
If that's not there, I'd uninstall the CE44 program and try reinstalling it. If it still doesn't work, maybe there is something wrong with the installation disk, if that's what you're using. Try installing it from the Vertex Standard site. You can download a .zip file of CE44. An account is free as is downloading any of the programming software.
Old 08-13-2014, 4:49 PM
Computer
OS C:
Vertex Standard
CE44 for Windows
ce44win.exe
I am downloading software from vertex Website, no disk. but will try again.
Old 10-03-2016, 8:42 PM
Default Missing CE44 exe resolved?
Hi this issue is exactly what I am facing, was there ever a resolution?
I've downloaded the software directly from Vertex's site, but after a successful installation on windows 7 64 bit PC, I have no exe to open the software. In the directory mentioned here I have the configuration and code plug files but no exe. Running a search for it turns up nothing, but if I go to the control panel and look at the installed programs I can see the CE44 software in the list.
I've tried re-downloading it to make sure the download wasn't corrupt and that was the same. I've tried the installer on another PC (Windows 8.1) with the same results.
Any ideas? Thanks for the help in advance.
Old 10-04-2016, 4:15 PM
cmdrwill's Avatar
I believe this is older software that does not put a Icon on the screen.
You would have to right click and use 'New Shortcut'. Look for CE44 and the .exe and click that.
You may have to run CE44 in 32 bit. OR XP compatibility..
Old 10-04-2016, 5:58 PM
Thanks for your reply, the issue is that in the directory with the other CE44 files there is no exe. I have the code plug files, and the configuration files, but it looks like the installer did not include an executable file. I checked the extensions on the file folder and none were .exe type. I have the programming software for the vx-400 (CE24) & vx-350 series (CE86) running just fine and both of those have the exe located in the same directory as the other files.
