VX-351 Audio on Tx Issue
MBill
Got a VX-351 portable with no audio on transmit thru internal mike. Works OK with speaker/mike
plugged in.
Replaced internal mike thinking it might have been bad, but no change. Thinking could be problem
with accessory jack as I have seen this happen with Motorola P110 radios.
The internal mike does disconnect when the speaker/mike is plugged in.
Anybody got a fix for this issue?
Thanks.
MBill
Turned out I had lost circuit ground on the internal mike due to damaged solder pad. Was able to get a nearby ground to connect to.
jeatock
090-45-50 W, 39-43-22 N
The VX-3xx radios have a common problem with the mic element falling loose. NEVER drop one on anything hard! I have fifteen on my bench traded in a from a school just like yours.
