I am trying to wire up a horn/lights at my fire department using a Vertex VX-2200 radio. I have found the service manual and am using the d-sub 15 connectors on the back of the radio. The pins are open collector outputs, which I have no experience with. I have already configured the radio to alert with the 2 tone decode. When I test pins 9-12 with a voltmeter I get 0VDC. With open collector outputs, do I need to use a pull-up resistor or should I run a diode across the relay coil to pull the current?
Thanks.
Here's a link to the service manual. http://www.repeater-builder.com/yvs/pdfs/yaesu-vx-2100-2200v-service-manual.pdf
Thanks.
