Go Back   The Forums > Commercial, Professional Radio and Personal Radio > Vertex Standard
Vertex Standard - Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 03-10-2018, 7:35 PM
Default HELP with EVX534
Hello all. I'm very new to DMR and vertex programming so forgive me please. I recently purchased 3 evx534s in uhf 403-470 for a steal. All three were brand new in the box with factory codeplugs. I programmed my friends ham repeater into channel 1 and the same analog frequency into channel 2. The analog channel works fine but the DMR channel will only give me about half a mile from the machine before it stops receiving. I can see activity on the channel by the flashing green LED and signal meter shows 2 bars but it just won't unmute. I have also noticed that unless I am very close to the repeater I cannot transmit as well. I get an error message on the display. I've tested this side by side with an xpr7550 which comes in clear and transmits without an issue. All 3 evx 534s act the same which leads me to believe that it's something I'm doing. Firmware was updated to the latest, programming done with CE-151 software and aftermarket cable. Thank you all in advance for your help!
All information here is Copyright 2012 by LLC and Lindsay C. Blanton III.Ad Management by RedTyger
Copyright 2015 by LLC Privacy Policy  |  Terms and Conditions
