Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Vertex Standard
Vertex Standard - Discussions regarding Vertex Standard professional and public safety radio equipment.
Old 06-13-2018, 6:13 PM
ftl7011's Avatar
Default P820 reband?
Good evening all
I have a vx-p824 that is Ver H (380.100mhz - 449.900mhz) trying to change it to Ver D (450.100mhz - 519.000mhz) I am using CE76 and following the same steps as noted in another post for the CE59 I am able to get into developer mode ok able to make all changes under common/hardware changes from H to D make the edits ok then when I try to write to the radio it says "Hardware Missmatch" anyone had this issue? Can anyone explain what " Adjustment Recover" & "Hardware Data Initialize" are used for? thanks 73
Old 06-13-2018, 7:25 PM
Originally Posted by ftl7011 View Post
Good evening all
Even if you can trick the software into thinking it is the version D, the RF circuits are tuned, and the radio will likely not perform very well outside its rated band split.
It is likely going to be easier to just buy the proper band split
Interoperatablity is not a technology, it is an attitude!!!
