Vertex vx-800 housing?
Danny37
New York City
Does anyone have the instructions on how to do a housing swap on the vertex vx-800? I've done them before on Motorola radios but there seems to be something more to it when it comes to this radio. Any info would be greatly appreciated, thank you!
GI_jose82
Manhattan, NY
It is fairly easy to do. First unscrew the channel selector and remove the power knob by pulling up on it. Once they are both removed each one has a spanner nut you need to remove. It can be done easy if you have a flat head small enough to get to it. Once that is done go to the rear of the radio you need to remove 3 tiny screws. After that peel back the sticker/ module or blank and remove the 2 silver screws. Once all that is removed just pull up on the front half of the house and it should come right off. Slip the new housing on and reassemble. Hope this was helpful and not confusing.
GI_jose82
Manhattan, NY
Danny37
New York City
Thanks, it was fairly easy to do. I didn't notice the tiny span in the antenna and ch selector but I got it off and replaced it.
