Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Virginia Radio Discussion Forum
Virginia Radio Discussion Forum Forum for discussing Radio Information in the State of Virginia.
Old 04-25-2009, 9:03 AM
Default Tone-Out Freq - Chesterfield & Richmond City
Does anyone have a list of Tone-Out Freq's for the City Of Richmond and Chesterfield Fire Department. I would like to have them by Company if Possable, then broken down by unit if need be. Or is there a place where I can locate them. Thanks in Advance.
C.G.
Old 04-25-2009, 12:09 PM
I don't think you'll find that for Richmond. There's no conventional fire simulcast, and the station alerting is done via a data TG over the trunked system.
If Chesterfield is still simulcasting over 154.16 (I haven't checked in a while) You may have better luck for them.
73/Allen (N4JRI)
Old 04-25-2009, 8:35 PM
trainman111's Avatar
Yes Chesterfield still does simulcast on 154.160. As for a list of tone-out frequencies, good luck. I've never been able to find one. I'm sure there's a list at the Emergency Communications Center, but whether or not you could get your hands on one is the trick. If you buy a Uniden BCD396XT scanner, it has a decoder which decodes the tone out frequency. What I am slowly doing is decoding the frequency via the computer by hooking the scanner up to the computer and running a program called audacity that decodes the frequency of sounds (in this case, the toneout).
Old 11-15-2012, 9:43 AM
Send a message via Skype™ to stubbe
The City of Fire Department, Richmond MI does simulcat on 154.100. I am trying to find out the tone out freq. as well. Going to try to talk to our dispatcher and find out.
Old 11-15-2012, 10:04 AM
Wiki Admin Emeritus
You'd probably have better luck measuring it for yourself using one of the many audio analysis tools such as Audacity. We have a PDF describing how to use Audacity linked in our wiki, along with other such analysis tools here... (go to the bottom)
Fire Tone Out - The RadioReference Wiki
HTH...Mike
Old 11-15-2012, 4:12 PM
I think we are talking about two different Richmonds. The city in question here is Richmond, VA.
