Brandon,
I'm located outside of Harrisonburg, and live in Bridgewater. I have a BC7 also. The only thing I don't like about it is programming it... otherwise it's been a decent scanner for me.
I think that lowband signals travel further than uhf. UHF signals are usually "pumped up" by a repeater, and as long as you can hear the repeater, you get everything. Same with 800mhz. Lowband sucks penetrating heavy concrete or metal buildings. Weather seems to be a factor on lowband also.
We use lowband paging for my fd. We will be going to uhf in the near future, as well as operating on 800mhz.
BTW Brandon, the telescoping antenna from radioshack is part number 20-006... $13something. Not an antenna to use when you are carrying the scanner alot, but something to use at home, etc. when listening to low-band... seems to do better on va state police, vhf-hi also. I can't say enough good about the Pro-95. There's even free software that you can download off the internet @
www.starrsoft.com , you just have to buy a two-way $15 or so cable. The manual does suck, though. The best thing to do is join the pro-95 yahoo group and ask questions/ read the files.
Also, if you get rechargable batteries, use NiMH. I use 1800 mAh in mine, but you can get higher. The higher, the longer the charge last. That's the good thing about the pro-95- you can take the batteries out and place them in a seperate charger... and put a fresh set of batteries in. The pro-95 does not waste batteries, the last about 24 hours on a charge.
Todd
