Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Virginia Radio Discussion Forum
Virginia Radio Discussion Forum Forum for discussing Radio Information in the State of Virginia.
Old 12-07-2011, 10:16 AM
SkyPager's Avatar
Default Dulles MWAA Re-banding
My sources tell me that the MWAA system at Dulles is being re-banded Monday - Wednesday of this week. Subtract 15 MHz. Work appears to be ocurring overnight. No other info available.
Old 12-07-2011, 12:03 PM
Wiki Admin Emeritus
According to the database, some of the freqs of this system have a '0' in the 4th decimal position, so some reprogramming, along with custom tables, will be needed for many scanners. See this message from our wiki forum...
Rebanding procedures
best regards...Mike
Old 12-07-2011, 04:35 PM
freqhopping's Avatar
Running UniTrunker on it right now, this is what I'm getting.
LCN 35 851.8875
LCN 61 852.5375
LCN 466 862.6625
LCN 476 862.9125
LCN 487 863.1875
LCN 657 Alt cc
LCN 658 Alt cc
LCN 688 868.2125 control channel
LCN 829 Alt cc
The radio tech TG is pretty active. But my Pro-106 is only partially receiving comms. It seems like when they're on 862.6625 I get nothing but static.
Spinning & Grinning
R10 - BC890XLT - BCD396XT - BCD996T- Pro-106 - MilTenna LP in the attic.
Old 12-08-2011, 08:03 PM
Today I loaded the rebanded table and was tracking the system fine.
Spinning & Grinning
Old 12-10-2011, 09:37 AM
j2brown's Avatar
I uploaded a new configuration using what is currently in the database to the RR.com owned PSR-500, providing the MWAA public safety feed, and it appears to stop on channels but I get no audio from the scanner. I'm hopeful that I did something stupid like mute something, and I'll discover it as soon as I publish this post. However, in the event that something else is awry, does someone have a PSR-500/PRO-106 configuration that I can try?
jeff
sdg
Live feed for Loudoun County (VA) Fire Rescue
RadioReference.com owned feeds for Fairfax County Fire and Rescue and MWAA.
Old 12-10-2011, 09:41 AM
You need to have this table programmed.
Spinning & Grinning
Old 12-10-2011, 09:51 AM
j2brown's Avatar
That looks like what I have, except I didn't have the 800 MHz "Rebanded" selected for the "Standard" band plans. I've fixed that. It's still stopping on channels, but there's no audio. A quick switch to WX shows me that the scanner can make noise and I can hear it through RR.com. Any other thoughts?
jeff
sdg
Old 12-10-2011, 09:56 AM
j2brown's Avatar
So the setting reverts to <select>, but maybe that's expected.
jeff
sdg
Old 12-10-2011, 10:15 AM
j2brown's Avatar
Old 12-10-2011, 10:21 AM
j2brown's Avatar
Tried changing Trunking Tables to Custom from Default. That was the issue. Operator error. Easy to fix, once you fix the operator.
Thanks for the help.
jeff
sdg
