Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Virginia Radio Discussion Forum
Virginia Radio Discussion Forum Forum for discussing Radio Information in the State of Virginia.
Old 11-13-2012, 11:25 AM
MOTORHEAD3902's Avatar
Default VHF Low skip into TriCities area
Like the title says, getting CHP- Orange1 channel (39.4000) in S9 at the house.
Haven't heard these guys in awhile...
DFFD
Old 11-13-2012, 5:29 PM
That is crazy. I heard some really bad interference on several VHF frequencies last night. I'm not sure if there is any correlation here.
Old 11-14-2012, 7:56 AM
Probably was, skip can interfere with local stuff. I heard too late that the 10 meter ham band (28 MHz) was open too.
"Freedom has ceased to be a birthright; it has come to mean whatever we are still permitted to do." Joe Sobran
Old 11-14-2012, 9:28 AM
Wiki Admin Emeritus
We're in the downward slide from a good sized CME that hit Earth yesterday. Conditions will probably be a bit unstable for another day or two
Old 11-16-2012, 7:15 AM
MOTOROLANUT's Avatar
We used to hear CHP skip and some kind of Mexican radio for a while.
Old 11-16-2012, 9:48 PM
If you don't mind me asking....what antenna are you using to pull in CHP. I used to get them in Portsmouth with an Antenna Specialist Antenna outside but that broke, and they don't make that model anymore. I have a Scantenna now but it doesn't perform nearly as good. Thanks.
Eugene KG4AVE
Old 11-17-2012, 10:20 AM
I use a coil-loaded VHF-Low mobile (I think it's a Larsen) on a homemade groundplane kit (4 x 16" radials at 90 deg separation) up at about 36 ft. It's fed with LMR400. Works just ok, but nowhere near as good as I had hoped.
DFFD
Old 11-18-2012, 12:16 PM
Thanks for the reply. Mine is mounted on a 20 foot mast on top of the house with Belden 9913 cable. If your getting CHP on a long bounce like that it must be doing something right. I was hoping for better performance with the scantenna as well.....like yours it is ok but no great shakes. Thanks again.
Eugene KG4AVE
