scotta3234
- Joined
- Sep 21, 2012
- Messages
- 2
Hello all,
I used to listen to several agencies here in Fairfax county, VA. About a year or so ago, I noticed that many of the agencies became increasingly, "garbled" though you could clearly hear certain parts. I was wondering if anyone had some advice of items I can check. Below you'll find a reference as to what I'm using, doing, listening to. Is it just a signal strength issue. I used to have no problems.
My scanner: pro-96 handheld with (800Mhz 7" GRE antenna)
Programming: via ARC96 (BuTel software) with radioreference.com import.
County System: P25
Distance from transmitting station: ~5-8 miles (estimating, but I'm in FFX city which is in the middle of the county and I believe I know where most of that is coming from.
Any help would be appreciated. Thanks.
County System: P25
