The call sign is WQBN419.
I took a drive to Rawley Springs today and it appears this is the location of the new tower. I took my handheld scanner, removed the antenna and had a faint CC signal without the antenna. With the handheld rubber duck antenna, reception inside the vehicle reception was excellent.
I will be in the Massanutten area the day after Christmas to double check however I was a little east of Harrisonburg today, did the same test, and I had no reception without the antenna. Still a little too far from Massanutten to be sure, though.
On a side note, how do you post a pic of a screen shot? I'll post a couple from Pro96com if I can figure it out on my laptop. Thanks.
