Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Virginia Radio Discussion Forum
Virginia Radio Discussion Forum - Forum for discussing Radio Information in the State of Virginia.
  #41 (permalink)
Old 06-12-2017, 12:09 PM
Drumbum's Avatar
Its been silent for me when I'm monitoring, I haven't recorded in a while, we have almost exactly a month in till proposed launch date
Sent from my VS995 using Tapatalk
  #42 (permalink)
Old 06-12-2017, 4:16 PM
kb4cvn's Avatar
Location: Nowhere near a paved road, away from the maddening world.
Town of Amherst PD was active on TGID 1101 today around 2 PM.
  #43 (permalink)
Old 06-12-2017, 5:00 PM
Drumbum's Avatar
Here's what my scanner got today,, sounds like crap
https://youtu.be/eYaF7ej6IBs
  #44 (permalink)
Old 06-13-2017, 12:11 AM
Ghstwolf62's Avatar
Sounds like your threshold settings are off. You might try adjusting them to see what happens.
I run manual 7 on both my 436 and 536 and pick up everything wonderfully from Roanoke to STARS.
When down in the area I'm picking the new system up great on those settings.
KJ4KFW
One of the few in the world apparently with radios & scanners that actually work like they're supposed to.
  #45 (permalink)
Old 06-13-2017, 12:12 AM
Ghstwolf62's Avatar
Yesterday from late afternoon off and on to about 1am this morning I was picking up TG 2000 on the system.
Seemed to be radio checks and such.
KJ4KFW
  #46 (permalink)
Old 06-13-2017, 8:03 AM
Drumbum's Avatar
Thanks,I will change the threshold,I never have had to with this radio so figured it was the way they were transmitting, I cannot receive the Amherst tower from where I am and my rooftop mobile antenna broke, got to get a new one
  #47 (permalink)
Old 06-13-2017, 1:04 PM
Drumbum's Avatar
Tried the threshold, didn't work, still the same, I notice certain people transmitting come in fine most are chopping, wasn't doing that until recently and only on that system
  #48 (permalink)
Old 06-13-2017, 1:56 PM
kb4cvn's Avatar
Antenna upgrade for your monitoring location.....Per our telephone discussion.
  #49 (permalink)
Old 06-13-2017, 2:12 PM
Drumbum's Avatar
That should get Amherst from here
  #50 (permalink)
Old 06-13-2017, 3:44 PM
kb4cvn's Avatar
Default Lynchburg TGID 5540 Active
Been active all day.
Sounds like water utility service operations.
Nothing being heard on the EDACS system's TGID's:
1298 - Lynchburg Utilities
1299 - Lynchburg Utilities - Meter Readers
All the addresses being mentioned are in Lynchburg City.
It makes sense to put non-Public Safety users on the system first, to find any deadspots. This could be the case.
Drumbum or Ghstwolf62 any comments, ideas, suggestions, wildass guesses from what you are hearing?
  #51 (permalink)
Old 06-13-2017, 4:04 PM
Drumbum's Avatar
I can't pick up the Amherst repeater what I'm hearing is the Lynchburg repeater, most of it is un readable and choppy some is crystal clear, I'm thinking its on their end because no matter where I put threshold its the same, sounds like they are just randomly talking, 1 transmission about every 30 min 2 different women and 2 or 3 men always 1 transmission, no conversations
  #52 (permalink)
Old 06-13-2017, 4:05 PM
Drumbum's Avatar
The TGs ive been hearing is 2200 and 5500
  #53 (permalink)
Old 06-13-2017, 4:39 PM
kb4cvn's Avatar
What I have been hearing here is on Lynchburg system, and is perfectly clear, almost analog quality recovered audio.
The one exception is one person who has a second radio on in the background, hearing a 1/4-second digital echo in their audio.
I am at the house in Amherst, using a portable with only a quarter wavelength whip.
  #54 (permalink)
Old 06-13-2017, 5:15 PM
Drumbum's Avatar
I'm hearing none of that on what I'm picking up maybe I ought to recheck my frequencies for each repeater everything I'm getting is broken up And the bcd436 needs all the help it can get sensitivity is crud on that scanner my $20 RTL SDR picks up way better with the little 98 cent telescopic antenna that came with it
  #55 (permalink)
Old 06-13-2017, 5:19 PM
Drumbum's Avatar
I finally could hit the Amherst repeater and I get the same talk group 5550 and one in the 2200 range
  #56 (permalink)
Old 06-13-2017, 5:20 PM
Drumbum's Avatar
Do you have everything programmed in like it's in the database on RR? As far as repeater sites I'm thinking that I am missing a frequency or one is in the wrong spot or multiple
  #57 (permalink)
Old 06-13-2017, 9:25 PM
Ghstwolf62's Avatar
I know Mark just updated things with new frequencies for control channels yesterday. Have you changed them over? I also know the original info I had freq wise and put into the scanner has changed. I wasn't picking up anything except what I had as the Bedford site. That may even have been wrong.
I haven't been back down there since I updated things last night so we'll see.
I'm sorry the threshold settings didn't work. I know mine sounded like your video before I changed them. You can go into monitor mode on the 436 and see the error rate then change it one at a time and watch what the error rate is for each inclination until you find what's best.
Do you have a good antenna on it? I'd check out the RS 800 which is a great multipurpose antenna and works for STARS and UHF too. Also the Diamond 77 works great although its rather long.
I'm surprised you're having sensitivity issues though. The 436/536 works beyond fabulously on P25 and I often pick up Roanoke's system going down 220 five or so miles outside Iron Gate. Its in and out due to distance but I do regularly get it all down 220 when heading that way. That's with a cheap mobile antenna from RS on the car's roof.
For outside I'd tell you to get an ST2 but for some bizarre reason they stopped making this antenna everyone loved.
Hope you get it sorted.
KJ4KFW
  #58 (permalink)
Old 06-13-2017, 9:29 PM
Ghstwolf62's Avatar
I only pick it up when I'm down in the Roanoke area, sorry. Can't pick it up clear up here. I know I got it full signal and clear as a bell Sunday in Troutville but lost signal going into Roanoke and while in the Valley View Mall area. Didn't pick it up until I was back in the Troutville area once again. Hope its not going to be absent in the Roanoke area. But so far not encouraged. Have picked it up near Carillon.
KJ4KFW
  #59 (permalink)
Old 06-14-2017, 8:33 AM
Drumbum's Avatar
Yes, I have a diamond and a RS-800
No, I didn't update with the new frequencies, I will re look at the database and make the changes,, that could explain why I'm not getting entire conversations . just spratic transmissions,, as for the choppy I will have to test it and see what the error rate us when I get the correct frequencies in there, was crystal clear a month ago on the same system .I am going on vacation starting tomorrow, will be using my GPS on the 436 as I go to Williamsburg until next Tuesday, after that I will have time to fix my database to correspond with the updated one
  #60 (permalink)
Old 06-14-2017, 8:52 AM
kb4cvn's Avatar
As of 08:45 Wednesday:
Folks in Bedford active on TGID 2000 this morning, discussing issuing radios.
Water Department active with operations traffic in Lynchburg on TGID 5540.
Lets see if anyone new joins the party today....
