Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Virginia Radio Discussion Forum
Virginia Radio Discussion Forum - Forum for discussing Radio Information in the State of Virginia.
Old 06-13-2018, 11:58 AM
Default Spotsylvania County SDS100
Having issues with the Harris system in Spotsylvania on the Uniden SDS100. I'm picking up the control channel for Fire and Rescue but it seems that it's not switching to the talk groups. I've tried a few things to improve reception to see if it's just a bad unit. Does anyone have a .hpe file that they can send me so I can import it in Sentinel to I can eliminate that as being a problem. It doesn't matter if STARS is included or not. Thanks for any help provided.
Old 06-13-2018, 6:47 PM
dhmann1811's Avatar
I have not had any issues monitoring the Spotsy system with my SDS100. It has certainly been better than my 436. I'm having issues downloading my .hpe file to RR. If you PM me your email address I will try to send it to you that way.
Old 06-13-2018, 7:54 PM
PM sent, thanks
Old 06-13-2018, 9:06 PM
Thanks Dave for sending the file. I've been monitoring just that file you sent of the Spotsy P25 and the past 45 minutes I've only received the Fire Dispatch which is TG 6001. When you monitor that system do you get a lot of traffic or are you just getting the dispatch channel? I will try it again tomorrow while I drive too. Thanks again Dave, much appreciate your assistance.
Old 06-13-2018, 9:29 PM
dhmann1811's Avatar
It is not necessarily a lot of traffic but you do hear dispatch and arrivals, enroute to the hospital etc. If itís an active scene they will go to an alternate fireground/tac channel and you can hear that as well. You might want to try to pull from the full database and check all your other settings. Are you able to hear STARS without any issues?
Old 06-13-2018, 9:37 PM
I haven't tried that yet. There are so many sites so I need to look them up so that I only install area state police and not Richmond or Northern Va so I'm not scanning a bunch of unnecessary sites. Thanks again, and I will keep you posted on the Spotsy P25.
Old 06-14-2018, 5:35 AM
jonwienke's Avatar
State police are not sites, they are departments. You can have unlimited departments and talkgroups programmed without affecting scan speed, because talkgroups are not scanned in trunked systems, only sites. Enable location control in your favorite list, and set your location and range appropriately, and the scanner will only scan nearby sites. Use a GPS when traveling, and the scanner will update what sites and channels it scans automatically as you go.
Old 06-14-2018, 7:03 AM
Thanks Jon
Old 06-14-2018, 10:51 AM
fredva's Avatar
It would not be too unusual for 45 minutes to pass with all of the fire/EMS traffic on talkgroup 6001, if all that is happening during that 45 minutes are medical calls. But when there is an accident, a fire alarm, or a structure fire, other talkgroups will be used.
PRO-18 upgraded to a WS-1080, PRO-197, PRO-2020, PRO-2021, 436HP, Raspberry Pi SDR
Fire & EMS feeds: http://www.broadcastify.com/listen/feed/527 & http://www.broadcastify.com/listen/feed/3331
Old 06-14-2018, 11:23 AM
Thanks fredva, I think over the weekend is when I should hear more. That's when all the crazies are out, lol.
Old 06-14-2018, 7:25 PM
fredva's Avatar
Default Service Types
Assuming that your version of Sentinel is similar to mine for my 436, go into your Service Types and make sure you have Fire Tac and Fire Talk checked as service types you want to monitor, and not just Fire Dispatch.
Old 06-14-2018, 8:43 PM
jonwienke's Avatar
Check the Multi types as well. If fire and EMS share dispatch, then the channel will be tagged Multi-Dispatch.
Old 06-14-2018, 11:56 PM
Thank you both for your suggestions. I will double check them.
Old 06-17-2018, 9:21 PM
Thanks Dave I still use the file you sent me and with the beta firmware that Upman sent my reception and communications have greatly improved. I;m now receiving talkgroups that I wasn't getting before.
Old 06-18-2018, 8:24 AM
dhmann1811's Avatar
Rick,
That is excellent news! Glad it is working better so now you will have to try STARS out. Stay in touch and let me know if I can help further.
Dave
Old 06-18-2018, 8:50 AM
Rick,
Dave
Much appreciated, will do!
Old 06-20-2018, 4:36 PM
fredva's Avatar
Spotsyrick, how clear is the audio you are receiving from Spotsylvania's system on your new radio? I know you are receiving more now than at first, but I was just wondering about the quality of the audio - whether there is any garbling or if it is pretty clear.
Old 06-20-2018, 5:21 PM
dhmann1811's Avatar
I canít speak for Rick, but I will offer my 2 cents on the SDS100 in Spotsylvania. My audio is crystal clear and much better than my 436 was. However, I am only about a half mile from a tower in the western part of the county. It has also been very clear while operating mobile. Also, monitoring STARS is very clear and better than previously on the 436.
Iím also interested in hearing Rickís feedback.
Old 06-20-2018, 5:46 PM
fredva's Avatar
Thanks for sharing. I'm glad it is working well for you.
Old 06-20-2018, 9:50 PM
The system is crystal clear. I don't receive any garble communications on the Spotsy P25. I'm to far out to get the Stafford/Fred system but when I'm driving that system is as clear as well. I did add STARS to my favorites and that picks up just as well. I usually don't scan that too much right now because it does take a few seconds to scan. I need to research that system more and only load the ones around me. Overall I'm very happy with the scanner, Uniden has a winner.
