Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Virginia Radio Discussion Forum
Virginia Radio Discussion Forum Forum for discussing Radio Information in the State of Virginia.
Old 08-23-2007, 02:42 PM
LEH's Avatar
LEH LEH is offline
Default Programming 396 for STARS
Folks, I've rummaged through the various threads trying to find the answer here. So far, nothing is working.
I have a BC396 and now that STARS is emerging in my area, I guess it is time to get it up and running. So far, no luck.
If I try to load the band plans, of course the step and offset are not supported, even with the latest firmware installed. Just using the P25 doesn't seem to help.
Other than the Uniden software, I am doing this pretty much by hand.
Any pointers would be greatly appreciated.
Lynn
Old 08-23-2007, 02:49 PM
LEH's Avatar
LEH LEH is offline
I may have answered my own question right after I hit the submit button, but I'll still take any help just to be sure.
What I hadn't done was go into the band plan AFTER setting the system up as P25. Still haven't heard anything, but I'll keep playing with it.
Lynn
Old 08-23-2007, 03:04 PM
dtscho's Avatar
You don't need to do anything with the bandplan with the 396. The scanner will read the information it needs from the control channel.
Dave
Old 08-23-2007, 07:13 PM
fmon's Avatar
Hi Lynn, hain't heard from you in a while. Though did note your check in to the roll call.
This is where ARC396 will help you very quickly. Fact is, it's fully functional for import and loading to the scanner right after download.
Frank
RR Wiki Programming Shortcuts
Old 08-23-2007, 08:01 PM
I have a BCD-396T and a BCD-996T. Make sure you have the control channel for Williamsburg (152.0675) or Hampton (152.5775 or 152.7575) programmed into the radio. That's all you really need to do under a P25 system. Depending on where you are in York County, you might received Hampton better. Unlike the Pro-96, the Uniden will set the correct tables (I also have a Pro-96). As you might have figured from reading the other posts regarding STARS, it is a challenge to receive.
Old 08-23-2007, 10:57 PM
W4UVV's Avatar
Smile Do the firmware upgrade
For type of system you must select "Motorola APCO 25" to properly receive STARS. If not already installed, be sure to download and install the latest 396 firmware upgrade to correctly process the STARS' multi-packet data streams. Otherwise you will experience periodic partial or total missed dispatcher/mobile or mobile/mobile comms.
Old 08-24-2007, 02:34 AM
which would be 1.13.17, right? just making sure
random scanner names that you really don't care about
Old 08-24-2007, 09:56 AM
Originally Posted by tuttleje
I have a BCD-396T and a BCD-996T.........
(Off Topic, sorry)
Perhaps you could help us with a question, assuming you are using BuTel software, are the .mem files interchangeable between the '396 and '996?, or how about the program itself-will it do both radios? I'm going to try to help CVASSB with a problem he is having with getting his '996 up and running here in the C'ville area.
Thanks!
20 wpm Extra
Old 08-24-2007, 12:22 PM
The software is not interchangeable. I have never tried to cross files from one radio to another (sorry). I use them for two different functions (portable and stationary) and have them structured in different formats. For example, I have different channels assigned to different talkgroups in the 396 than in the 996 (on the WMBG/JC/YC system). Also, each STARS tower is set up as separate systems in the 396 rather than one system with different sites in the 996. As a result, it is easier for me to download the files from the RR database and then manipulate them to fit my needs.
My setup on the 996 is that I use a null modem cable to connect the rear 9 pin serial port on the radio to the serial port on the computer (works great). With the ARC996 software it logs all the transmission and through the "rec" jack on the 996, it connects to the computer to record all the audio to a 380 gig USB drive (which I dump every day). I also use a Pro-96 with Pro96com to monitor the control channel on the P25 system (WMBG/JC/YC). Therefore, I can "see" all activity with the Pro96com and hear/record with the 996. It makes for a great combination to analyze a system, or follow an incident. If I want to lock in on one talkgroup, I can hold and record on the 996 and scan all the other talkgroups with the 396.....all the time letting Pro96com display all activity on the system. It works great to have Pro96com on the computer display and the ARC996 virtual control superimposed at the bottom of the screen. Attached is an image of what it looks like. Sorry if I got carried away.
Old 08-25-2007, 05:22 PM
W4UVV's Avatar
Smile Sounds right
I don't know the version. I have the 996T. The firmware upgrades for both wer released around February of this year.
Old 08-25-2007, 06:30 PM
According to Uniden:
BCD396T Announcement
01/04/2007 10:19 AM
v1.13.17 Firmware Update Available
Old 08-25-2007, 08:26 PM
LEH's Avatar
LEH LEH is offline
Default software interchangability
One thing you may want to do is to look at the actual data file in an ASCII editor. I don't know how the 996 files look in comparison to the 396 files, but UPman told me once that there were only minor differences in the header files between the 396 and 246. So for the real guts of a file, it may be very easy to copy and paste.
Lynn
Similar Threads
Burlington Co. 396 programming policefreak New Jersey Radio Discussion Forum 13 06-28-2007 10:15 PM
programming 396 robhearn Delaware Radio Discussion Forum 3 03-08-2007 03:40 PM
Programming the 996 with the 396 sortware kc8syo Uniden Scanners 6 12-20-2006 07:46 PM
396 programming question joetnymedic Connecticut Radio Discussion Forum 10 06-10-2006 09:14 AM
396 programming question joetnymedic Uniden Scanners 3 06-05-2006 07:31 AM
