Old 09-13-2009, 8:47 PM
slypx's Avatar
Quebec DB Adm
Default BCD396XT with Pro96Com
I've been using Pro96Com with GRE's PSR600 for over a year and just received a BCD396XT three weeks ago and started using Pro96Com with it.
What I find ackward is that I have to lower the port setting to 9600 bps on the PC, on the BCD396XT and on the software underwise I loose connection within 5 minutes after started to decode ...
I've never changed anything on the PSR600, it's always at 115000 bps...
Any thoughts on that anyone ?
Slypx
Quebec DB Admin
BCD396XT | PSR600 | PSR500C | BC780XLT | PRO2006 | PRO2046 |
Old 09-14-2009, 7:22 AM
ac7xc's Avatar
Are you use a USB device? I am running a BCT15X @ 115k, but I use a USB serial port adaptor made by FTDI. The FTDI chip is the same one used in the Radio Shack 20-047 cable. Some USB devices are not very good with intensive use that is used with digital transmission and decoding. I use a
US232R-100 cable and works flawlessly with Windows XP through Win7 32/64 bit, MAC OS X and Linux.
It really is a great product and it has removed all my Serial to USB problems with all my radios and modems.
____________________
Best Regards, Keith http://home.comcast.net/~kilowattradio/
BCT15X PRO-433 PRO-107 PRO-106 PRO-92 PRO-83 BC346XT BC245XLT BC250D TH-F6A FT897D
bcprogtool.tcl for XT
Old 09-14-2009, 10:16 PM
slypx's Avatar
Quebec DB Adm
I use the Uniden USB cable who works fine in uploading or downloading at 115000 ...
Slypx
Quebec DB Admin
Old 10-05-2009, 7:08 PM
slypx's Avatar
Quebec DB Adm
More Info ...
On the scanner, I have a full 5 bar signal and the tower is less than 5 miles from my listening post, signal is not a issue here.
I've used 2 different Uniden USB-1 cable on 2 different PC on different comport on each and even tried the serial cable without more success ...
So I'm left with a problem that could be in the configuration of the software, configuration of the scanner or something's wrong with the scanner itself ?
Uploading programming to the scanner seems fine.
Anyone have a better config or success than that ?
Any idea anyone ?
Slypx
Quebec DB Admin
Old 10-06-2009, 7:59 AM
mrscanner2008's Avatar
Hi
I have the same problems with my 396XT and Pro96com. I tried all bauds settings down to 38400 to make it works. So far 38400 works fine for me but nothing higher.
But with freescan, proscan, etc I set the bauds rate to 115200 and all works fine.
I didn`t try my 996xt yet.
Mrscanner2008
WWW.VE2DRO.COM
Icom IC-91AD, Yaesu FT-8900R, Icom IC-7000, KX-3, FTM-400DR (Fusion),Icom IC-R20, BCD396XT,(2)BCD996XT, PSR600, HomePatrol 1, (2)BCT15X, (2)BCD436HP, BCD536HP and TRX-1
Old 10-06-2009, 8:42 AM
mikey60's Avatar
Originally Posted by mrscanner2008 View Post
Hi
Mrscanner2008
I have no idea why this would be the case, as it works fine for hours on end with the PSR-500/600 at 115200. I don't know if the data coming out of the radio is still clean or has somehow changed. What does the raw dump screen look like when it stops?
http://www.psredit.com
Old 10-06-2009, 9:56 AM
slypx's Avatar
Quebec DB Adm
Hi MIke,
You're right, I can leave my PSR600 running for hours or days without a glitch, but with the 396XT ... it's painful just to keep it running for 20 minutes ...
Thanks for looking into it and keeping us up to date on your findings.
Slypx
Quebec DB Admin
Old 10-06-2009, 3:30 PM
slypx's Avatar
Quebec DB Adm
Just happened
Started decoding 2:58 pm, stopped 3:19 and raw dump screen went blank at that moment.
At 3:32 it started again to decode by itself but NO RAW DUMP activities ...???
Prior to going empty at 3:19, it started to show odd things and longer strings of code than normal and among these it showed the following ones :
5,3,000B4A60006C000EEAD9CDFE25,5,300B130000016BE97 CEA44FP2525090000000E000009F0B2264
P2P28090006BE0FFEA6FFA6BFF66
P2340A0082D1280101797970C0
P,3B09032C8032000010A007948025,5,00030000FF00FFF00 052E5F725,5,8000004F00010964E0D934AP2525990903000D 02000DD00D04A
P2009B0064EEE0ED6F05047049
P,853D00002200020A0000FFF7
P,851600001A6C020EEA797B576825,5,B0130010320209790 044FDFP2525,0000EAE00A6F096B004435FP25254002082D00 001F000FF5035
P2P2BA0090114BE2010A69706268
P,BABB0011BEE0004F000970F3
5,0,BBEA60BA6B2800000A05F7C7
5,8,100000000FFF000F7935A26P2525,90E000ED6F02DD891 8E062
P2P25B00900EE0004F0064704434
P2P25,000022D1090A2409A2640E
P2P216090040F10F010009700068
P,BA0090116BE201EA79761DFE46
5,09940B40826DE801EA6618D7
5,8,300000B0000140001035F3A025,5,90EA004A6EFA6DEFF BC6B6DP2525,001002D04F0F0909704486
P2P2BB0990BEE0004F0A6C006E66B4
P25,8090E2D0EAFFFA6FFF6ED5
P2BA059011400201EA797D6468
P,BABD0B4322000209000562FE
A25,0,B0EA13B9C901498D790E90C025,5,30022589C92409F FF0D1B6DP2525,900000EAFFFA6EFFFDBB86
P252B40A0082D14F01D000180036
Slypx
Quebec DB Admin
Old 10-06-2009, 7:52 PM
mikey60's Avatar
Originally Posted by slypx View Post
Just happened
The question is then, is that what the scanner is putting out, or is there something else going on. I'm not sure how to figure that out at this point.
Old 01-11-2011, 4:38 PM
N8IAA's Avatar
Default Hate to bring up a year + old thread...But...
I just got a 396XT a little over a week ago. No joy using the Uniden USB-1 cable. Tried multiple connect rates. Under scanner control heading, it shows the 396, but using COM 3. The 396 is connected to COM 5 and I can't change the setting.Nothing. No problems with any of my RS/GRE radios. Been using this program since my Pro-96 scanner in '03. Any ideas Mike?
TIA,
Larry
Old 01-11-2011, 5:15 PM
GROCKSHD's Avatar
Mine works great, no problems at all. I normally connect at 57600, but switched to 115200 to see how that works, and no problems. Connected using USB-1.
Larry, are you able to connect to any other programs via the USB cable?
Garrett K4FML
2016 Wrangler JKU
BCD436HP, TH-D72, TM-D710, FTM-400XDR, STRYKER SR-955HPC
Old 01-11-2011, 5:25 PM
N8IAA's Avatar
Indeed. I use FreeScan on the same comport. It runs the scanner control there without a problem. Even upgraded to version 1.9.6. Sees my 197 great. No joy on the 396XT.
Larry
Old 01-11-2011, 5:29 PM
GROCKSHD's Avatar
I know this may sound elementary but when you are in PRO96COM and click on Edit>Decode Information> and select RESCAN, Are you able to click on the drop down box or is it light gray?
Garrett K4FML
2016 Wrangler JKU
Old 01-11-2011, 9:42 PM
N8IAA's Avatar
Nope. Can click on the drop down box. It is set for the correct com port. Just does not see the scanner. When I use the scanner control for FreeScan. Not a problem. Logging works, etc.. I guess that it will be FreeScan for the 396 and Pro96com for the GRE/RS's. No big deal. Just wondered why.
Thanks,
Larry
Old 01-11-2011, 10:07 PM
mikey60's Avatar
Thanks,
Larry
Did you turn on the option in the scanner to send the CC data to the serial port?
Old 01-11-2011, 10:52 PM
N8IAA's Avatar
No, I didn't. New scanner, learning as I go I knew it had to be something simple again Thanks, Mike.
Larry
Old 01-14-2011, 10:42 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Larry
To add a little something:
I would go with just "ON" and not "Extended" for the CC output Larry.
At least I have found best results that way.
Happy Monitoring
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
All opinions are exclusively those of the author
and in no way reflect the position of his employer,
contractors or other parties.
Old 01-14-2011, 11:23 PM
N8IAA's Avatar
Happy Monitoring
Marshall KE4ZNR
Thanks, Marshall. This scanner has been getting easier to understand each day
Larry
