Closed Thread
  #441 (permalink)
Old 03-12-2014, 11:39 PM
Originally Posted by mtindor View Post
If -v4 doesn't give you talkgroups, then you are SOL. Try -v4 though.
Thanks -- with that switch the display showed "[E] Channel Group & User: tg=546" on every transmission, even though different TGs were active. I tried a tap off an analog and digital scanner with the same results, so it looks like I'm out of luck. Strange that with the regular DSD the correct TGs show up without a problem.
  #442 (permalink)
Old 03-13-2014, 1:36 AM
mtindor's Avatar
OH/WV DB Admin
Is 8736 meaningful as a talkgroup ID to you?
In the RRDB, if you were to look at a 'decimal' talkgroup, you might see something like 16960, and then a hex value of 424. Well, 16960 really isn't the decimal equivalent of 424 hex. The decimal equivalent of 424 hex is decimal 1060. RRDB shows it as 1060+16 = 16960.
So you might see 546, which is decimal. Hex value would be 222, and RR decimal would be 8736.
222 (hex) = 546 (decimal) = 8736 (scanner-flawed decimal, which is what we display in RR).
There is a reason behind that. A sage once told me the whole story behing why 'decimal' on a scanner really isn't the decimal equivalent of a the hex counterpart. Blame it on a certain scanner manufacturer that it is that way
Mike / AA8IA
PSR800/PRO197/BCD436HP/BCD536HP
  #443 (permalink)
Old 03-13-2014, 1:58 AM
Default DSD Plus download
This link from the Wiki does work:
https://mega.co.nz/#!dxBEES5T!URN1d1...GaF9oP_42vUHaE
Make sure you aren't blocking the Flash / Silverlight or whatever the hell it uses. But it definitely does work.
Thanks Mike! Internet Explorer 11 did not display it but Mozilla did and the download was successful.
  #444 (permalink)
Old 03-13-2014, 3:38 AM
mtindor's Avatar
OH/WV DB Admin
You're welcome. I'm glad you were able to get it
  #445 (permalink)
Old 03-13-2014, 11:13 AM
Is 8736 meaningful as a talkgroup ID to you? Mike
Yes, 8736 is the equivalent talkgroup! So through some mathematical magic, it is working after all. Thanks!
  #446 (permalink)
Old 03-14-2014, 1:18 PM
jcardani's Avatar
Actually the reason it is that way makes perfect sense. It comes down to the handling of the 16 status bits (or t-bits) of a type II Smartnet Motorola talk group by the scanners. (The status bits handle patch, all group, emergency, encrypted, etc. status) With early scanners you needed to program the 0 status bit for regular talk group.
See:
Motorola Type II Smartnet - The RadioReference Wiki
Joe Cardani, W3FOY
Owner, PhillyScanner Yahoo Group and Greater Orlando Communications Group
  #447 (permalink)
Old 03-14-2014, 5:23 PM
jdobbs2001's Avatar
I was able to download it from the megaupload site. use Firefox and it works, ie11 does not. Decoding mototrbo and nxdn48 with no problems.
  #448 (permalink)
Old 03-23-2014, 10:50 AM
Unhappy 2 RTL and 2 Sdrsharp programes with Unitrunker help
Ok I will do my best here I have 2 RTL dongles set-up and 2 SDR Sharp programs running and I also have DSD+ for decoder. Now My control sdr folder has the trunker plugin and is taking tons of stuff off the Unitrunker
now the voice fold with sdr when I have the voice sdr running what Freq should it be set to. Why I ask is that the sdr control that is taking in the trunked signals jumps around like it should FREQ To FREQ I don't think I have the voice on set right because the DSD+ may show one if that voice decode in one hour as the control sdr is showing tones of stuff coming in. Sorry very new to this so sorry if it is confusing a little. In a nut shell I'm just trying to get the DSD+ to decode better heres a screen shot of the control data coming.
Thanks a bunch new member Foxy647130 AKA Johnny D.
  #449 (permalink)
Old 03-23-2014, 11:02 AM
jasonhouk's Avatar
You'll need 3 VAC running
one for the control ch decode
one for the line in to dsd+
and one for the dsd+ output
The 2nd receiver (sdr) will need the unitrunker plugin running.
some sdr and dsd+ tweaking may be needed after depending on the system you're monitoring.
  #450 (permalink)
Old 03-23-2014, 11:16 AM
ok how to I setup the You'll need 3 VAC running
I have only 2 right now one for control and voice I will add another right now wich is easy but how do I setup for the dsd+ I know sdr on choose from the drop down boxes but not sure how to do it with DSD+
  #451 (permalink)
Old 03-23-2014, 11:20 AM
jasonhouk's Avatar
Sent you a PM
  #452 (permalink)
Old 03-23-2014, 11:35 AM
Sorry super new whats a PM. I just added another line so now I have three and I added the trunking plugin to my other sdr voice file now just the DSD+ I need help with PM HMMM I don't think I know how to get that or make it sorry
  #453 (permalink)
Old 03-23-2014, 11:39 AM
jasonhouk's Avatar
A private message under RR forums. You should have 1
  #454 (permalink)
Old 04-01-2014, 8:06 AM
Thumbs up DSD + ( -XR )
Hello
I found a good software but in the last edition Ď Ėxr í control is missing
Iím referring to dsd+ version
Iím wondering if I havenít seen it or it doesnít exhist
Thanking you in advance for your reply
Best regards
  #455 (permalink)
Old 04-01-2014, 2:29 PM
br0adband's Avatar
Originally Posted by iw2dtt View Post
Hello
I found a good software but in the last edition ‘ –xr ’ control is missing
I’m referring to dsd+ version
I’m wondering if I haven’t seen it or it doesn’t exhist
Best regards
DSD+ automagically detects the polarity (?!?!) of the DMR/MOTOTRBO signal it's decoding and adjusts itself accordingly, the -xr switch is for DSD only (the older and original digital speech decoder) which could not do automatic inversion of the incoming signal.
DSD+ doesn't need such a switch, it's all done for you when you decode something.
The difference between genius and stupidity? Genius has limits.
  #456 (permalink)
Old 04-03-2014, 4:53 PM
You need 2 lines
Line 2 to feed unitrunker and line 3 to feed dsd+
  #457 (permalink)
Old 04-03-2014, 5:13 PM
so how do I feed dsd+
  #458 (permalink)
Old 04-03-2014, 5:16 PM
I'm buying a pro 106 is it true I don't need it tapped
  #459 (permalink)
Old 04-11-2014, 3:02 PM
NDRADIONUT's Avatar
I cant get the download to work... Can someone send me the original zip file ?
  #460 (permalink)
Old 04-11-2014, 3:12 PM
RonnieUSA's Avatar
I just tried the link, and it worked, but here yea go.
PSR-800 - BCT15X - FreeSCAN - NooElect R820T2+ SDR - NooElect R820T2 SDR - DSDPlus Fast Lane
Closed Thread
