Closed Thread
  #81 (permalink)
Old 08-05-2014, 6:36 PM
Seņor Member
Hi bigbud;
Originally Posted by bigbud42010 View Post
it always says 1 device found but is busy i have done everything reinstalled drivers I can't get it to work I just want to throw it in the trash
What tuner chip does your RTL stick have? Unitrunker only supports RTL sticks with the R820T chip. For other tuner chips like the E4000, you'll need to use a separate program to control the RTL stick and pipe discriminator audio in through VB cable or VAC.
Does the device work with an SDR program like SDR#? Can you see a water fall display?
  #82 (permalink)
Old 08-06-2014, 9:19 AM
Default Amazing
Unitrunker absolutely amazing!
  #83 (permalink)
Old 08-30-2014, 6:49 AM
Does anyone have the logout and login entries doubled (they appear 2 times) monitoring a p25 system on version 28.4? Don't remember or notice this on previous versions.
  #84 (permalink)
Old 08-31-2014, 4:17 AM
After some log diagnostics it appears that the duplication is what the system is transmitting.
  #85 (permalink)
Old 08-31-2014, 1:03 PM
joeuser's Avatar
When upgrading from the last version to the new version - what changes? I tried to upgrade twice now & when I do I lose my audio...
HP-1E,BCD436HP(2),996XT,396XT(3),396T.BCT15X(5).BC250 &296D,780XLT(3).PSR600(2)&800(2).Pro-197(3),164(2),163,2006(2),2001,42,37,21A.TRX-100XLT.DX-440.CenterFire-MultiBand&Discone,ST2,Spider
  #86 (permalink)
Old 08-31-2014, 1:28 PM
Seņor Member
The program is supposed to filter out duplicates. I'll check this out here.
  #87 (permalink)
Old 08-31-2014, 5:13 PM
Let me know if you need a log file.
  #88 (permalink)
Old 08-31-2014, 11:39 PM
Seņor Member
Thanks Rock. This should be fixed in the next release.
  #89 (permalink)
Old 09-01-2014, 10:30 AM
joeuser's Avatar
Mr. Unitrunker, Sir...
Sincerely, Me
  #90 (permalink)
Old 09-01-2014, 12:39 PM
Seņor Member
Joe - what version are you talking about?
The only version relevant to this thread is 1.0.28.4 - which is the latest official version.
If you've grabbed something from a preview folder - those are experimental. Sign up to the Google groups mailing list if you want to participate in preview testing. Otherwise, it is best for you to stick with latest the official version.
  #91 (permalink)
Old 09-01-2014, 3:44 PM
joeuser's Avatar
Thank you for your reply.
I have the last official? version: 1.0.27.19.
When I install the new one 28? I get no audio. Something gets broke, I move my original files back & it works fine again. ( I manually copy the dir for a backup before I install the new version).
What changes take place between these two versions that would make it not work properly? I'm sure its a setting but I can't figure it out. Listen to a P25p1 system on 8xx range. DSD+. Screen shot is a few posts above.
Thank you again, I appreciate any efforts on my behalf.
  #92 (permalink)
Old 09-01-2014, 8:23 PM
Hello,
I'm wondering if you can help me out here. I'm completely new to this.
I'm using the latest version of UniTrunker and am following the guide located here.
I've managed to set one of my radios tuned to the control channel and it's displaying a list of calls.
I'm stuck with the second radio, however.
For the Voice Channel Receiver, I see that the guide directs me to set the gain and PPM offset. I'm not sure what I should be using here. I've tried the values displayed in the guide's screenshot.
I have "Park" set to 0 and other settings matching OK.
All I get is hiss from both the analog output and DSD+ recordings. (DSD+ doesn't seem to be outputting anything via the speakers 'on the fly', however).
I have enabled UniTrunker Following by setting "Listen" to enabled.
So I'm not sure if UniTrunker is setting the voice receiver to the appropriate frequency based on what's coming in from the Control channel or what could be going on here.
This is the system I'm attempting to listen to: Capital Region Emergency Services Telecom (CREST) Trunking System, Victoria, British Columbia - Scanner Frequencies
Thanks!
  #93 (permalink)
Old 09-01-2014, 11:59 PM
Seņor Member
Originally Posted by joeuser View Post
What changes take place between these two versions?
Please read the very first post in this thread.
http://forums.radioreference.com/tru...ml#post2224665
  #94 (permalink)
Old 09-02-2014, 12:19 AM
Seņor Member
Hi tech;
That tutorial is fairly good but is slightly out of date. This link may help ...
UniTrunker | Realtek
To determine the warp value - you'll need to use another program that provides a waterfall display. The idea is to tune to a known frequency. Expect to see the actual signal some distance away. Increase the correction or "warp" factor until the signal lines up. Save that warp value for later. Note that the correction factor is not the same as a frequency offset which is usually needed when you're using an up-converter. That does not apply hear so leave any offset frequency at zero.
Park the voice receiver on known local station like NOAA weather radio. If there's an active analog voice channel - use that. Adjust the gain up or down as needed. Also adjust the squelch. Once you've got it to your liking, you change change the park frequency to zero.
The Calls tab of the site window will display the list of channels with any associated frequencies. If they're zero, the program won't be able to tell the voice receiver to tune to an active call. A band plan maps channel numbers to channel frequencies. Some Motorola systems use a standard bandplan. Your system requires a custom plan. You can fill out the details on the Bandplan tab of the site window. You can also use the download feature to pull down the bandplan from the RR DB.
From the link you provided, the plan is simple - only one row is needed.
Base frequency is 139.635 Mhz. Step size is 15 khz. "Lo" channel number is 380 and "Hi" channel number is 759.
  #95 (permalink)
Old 09-02-2014, 1:46 AM
Hi tech;
Ok, I think I got that bit figured out now...
This is where I start to get a little puzzled. A local Weather Radio station here is at 162.400. All I get is hiss using SDR# or UniTracker. There's a very narrow peak in the spectrum analyzer, but no audio besides hiss.
If I tune to a local FM radio station, it comes in crystal clear. So I'm not sure if my antenna is poor, poorly placed or what.
The channels and calls tabs are displaying several frequencies. With the exception of the 143.685 control channel, they're all in the 853-867 range. The calls scroll in the bottom half of the window, and the "Target ID" is briefly displayed next to one of the frequencies up in the top half of the window. (I'm assuming this is the frequency that gets passed onto the Voice receiver for tuning).
So it appears that the calls are being properly tracked on the frequency, I just need to figure out how to get the voice receiver to pick up a frequency properly.
  #96 (permalink)
Old 09-02-2014, 9:45 AM
Seņor Member
You can use the control channel to calibrate your voice receiver. Try turning on baseband AGC and tuner AGC.
That's not good. Click on the band plan tab. There should only be one entry for 138.635 Mhz. Any entries in the 800 Mhz range don't belong there. You'll need to delete those.
  #97 (permalink)
Old 09-02-2014, 10:15 AM
joeuser's Avatar
Dear Unitrunker,
Yes, thank you. I read that the day you posted it - in fact - I replied to it as the third post. So, what changes would make this latest version not work when the previous one does. I think I'm missing a setting change? I can't figure out what I'm missing.
Sincerely,
Me
  #98 (permalink)
Old 09-02-2014, 10:36 AM
Are you hearing analog at all or is the system pure digital? I can see from DSD that its decoding, check your DSD audio output option, it might be set to the wrong output.
  #99 (permalink)
Old 09-02-2014, 10:57 AM
Interesting.
Ok, I went into the band plan tab, removed all the 800+ entries and added the 139.635 (you're a number off in the quote above, but correct in the previous quote).
When I save, stop and restart the radio, it still shows all the 800's in the call history and frequency table.
  #100 (permalink)
Old 09-02-2014, 11:01 AM
Aargh! I didn't set the "Hi channel number" correctly.
Now this is what I'm getting:
Closed Thread
