Old 09-01-2014, 3:27 PM
cellphone's Avatar
Default ProVoice Talkgroups
Can anyone confirm or deny this….. I am reading that a GRE PSR-800 with firmware version 1.06 will follow ProVoice talkgroups, and play the digital noise through the speaker. I am also reading that this functionality was taken away in later versions of the firmware. Is this all correct?
If the PSR-800 will track ProVoice, then it would be simply running an audio cable from the headphone jack to the input of a computer and running DSD to decode. Is anyone doing this?
Old 09-02-2014, 12:26 AM
Señor Member
cellphone - short answer is yes.
Old 09-02-2014, 2:59 AM
cellphone's Avatar
Ok, so the scanner can follow ProVoice talkgroups, but not decode the audio. What is stopping Whistler from making a deal with the author of DSD, and integrating that audio decoding into a scanner?
Old 09-02-2014, 8:15 AM
n4yek's Avatar
ProVoice is proprietary and owned by MA/COM
Danny
A blood donor saved my life (Matthew 26:28)
If 'con' is opposite of 'pro', is Congress the opposite of progress?
Old 09-02-2014, 11:42 AM
cellphone's Avatar
Are you implying that the authors of DSD are not reverse engineering or using generally available/open source codecs to decode ProVoice, but rather stealing code from Harris (MA/COM)? At a high level, decoding ProVoice seems very similar to when Terry Brennan and company reverse engineered the proprietary EDACS trunking format in the mid 1990’s. EDACS decoding has been part of almost every trunked scanner since then. Why can’t this also be done for ProVoice?
Old 09-02-2014, 12:21 PM
n4yek's Avatar
I didn't imply anything, just stated a fact.
Danny
Old 09-08-2014, 11:45 AM
Radioman96p71's Avatar
I don't think the hard part is for manufacturers to get this built into their scanners. (they probably have some sweet engineer models that already do for all we know).
The hard and expensive part would be the legal storm that would erupt from DVSI / Harris and convincing them they used open-source code and not proprietary (licensed). I don't know enough about copyright law or specifically HOW ProVoice is specifically protected. If they managed to get the entire theory copyrighted then even using DSD/DSD+ would violate that. Long story short, I think the legal grey area is too much risk to them for the very small demographic that wants PV support.
N0MB
Adam K
Polk County, Iowa
Old 09-08-2014, 11:55 AM
yes it will with 106 I had it on my 800 and lost it with filmware 108 and could not get back to 106
