D
DaveNF2G
Guest
I am scanning a 3-repeater Capacity Plus system on UHF. I have set the following information into the dsdplus.frequencies file, but the TX frequency never displays in the Channel Activity window where there is a column for it.
Cap+, 123, 0, 2, 463.31250, 468.31250, 0
Cap+, 123, 0, 3, 463.43750, 468.43750, 0
Cap+, 123, 0, 1, 463.82500, 468.82500, 0
There is no actual network ID. I set zeroes as per the comments in the file. The channel numbering I used is based on which repeaters have which "channel" numbers on them.
In other words, on 463.825 slot 1 is channel 1 and slot 2 is channel 2. On 463.3125 slot 1 is channel 3 and slot 2 is channel 4. On 463.4375 slot 1 is channel 5 and slot 2 is channel 6. This is all per what shows in the Channel Activity window.
How should the above entries be modified in order to get the TX frequency to appear?
