Release 30
Now using a WIX installer so, before upgrading, examine your start menu short-cut. Make a note of the *working* folder. After upgrading, you may need to hand-edit the new shortcut(s) working folder to point to this folder.
Edit: don't use the desktop short cut created by the installer (delete it). Launch the program from the start menu instead. On Windows 8.1, you can use the "Pin to task bar" option to make launching the program more convenient. See this thread for detais. Thanks to Saint and moonbounce for their feedback.
Decoding
a. Discover mode check box (replaces the receiver lock mode combo box).
b. Pick site dialog - accessible from Site window tool button; grab a previously logged site and point signal receiver to it.
c. Chase control channel behavior much improved for all receiver models.
d. Dwell time for control channel chasing is more accurate.
e. Prevent crash when user deletes a running receiver (don't delete it).
f. Edits to park frequency (re)enable Discover mode.
P25
a. RR DB download of "zoned" P25 systems didn't retain all downloaded information.
b. Guard against unlikely (but actually happened) scenario where second TSBK of multi OSP passed the 16 bit CRC check but wasn't a single OSP message. The number in the "follow" TSBKs field was crazy high (100 or more) which caused problems downstream.
c. P25 issues monitor events.
Motorola
a. RR DB download of OmniLink systems didn't retain all downloaded information.
b. RR DB download - ignore nil fleetmap for non-Motorola systems.
Display
a. Joins to same talk group more than 3 seconds later are logged (previously these were not logged).
b. Update site's last seen time stamp.
Voice Following
a. Clear call type when clearing old calls.
b. Propagate digital call type for grants.
c. Call mask is now 16 bits (more than 8 call classes).
d. Hack for mixed encrypted / clear digital calls on P25.
e. Bug fix for voice class on P25 continuations.
RTL2832U
a. Automatic fine tuning for RTL2832U receivers (requires squelch setting "full quiet" when no carrier present).
b. Squelch setting in decibels.
c. AFC with better modelling formulas.
d. Limit UI entry of warp value to +/- 250 ppm.
e. AFT logic now has guardrail to restrict auto correction to fit within channel bandwidth. Roughly +/- 7 ppm at 851 Mhz.
f. Zero squelch turns off AFT.
g. Tweaking correction value turns off AFT.
HP-1E
a. receiver window missing mute, analog and digital WAVE outputs, and de-emphasis check box.
Additional information on discover mode and the pick site dialog.
Chase | Dwell | Discover | Pick Site | Pollution
Download
Index of /download
Decoding
P25
Motorola
Display
Voice Following
RTL2832U
HP-1E
Download
Index of /download
